Bootloader 328 problems
by richile on Fri Apr 24, 2009 6:01 pm
I have the the Atmega 328 on the Diecimila board. I am using a Mac w/OSX 10.4.1.1. I have tried IDE versions 15, 14, 13. 13 is the only version that has "Arduino w/ Atmega 328" on the board selections. I have tried all of the different tricks in every version including changing changing the baud rate in the "boards.txt" from 57600 to 19200 and back again in all three versions. I purchased the IC from Adafruit. Why is this happening, or not ? I have had so many problems with this duino. Any suggestions?
richile
Re: Bootloader 328 problems
by adafruit on Fri Apr 24, 2009 9:27 pm
when you press reset does the LED on pin 13 blink a couple of times?
by richile on Sat Apr 25, 2009 12:06 am
No.
richile
by adafruit on Sat Apr 25, 2009 9:46 pm
hmm. that is a problem. are you sure its in the right way? none of the chip leads are bent under? (one has to ask)
by richile on Sun Apr 26, 2009 1:15 pm
It is in the correct way and there are no bent pins. I wish that there was something obvious like that but alas, there is not.
richile
by adafruit on Mon Apr 27, 2009 11:37 am
sounds like you were unlucky! please email support@adafruit with a link to this thread and request 2 bootloader chips be sent to you
by richile on Mon Apr 27, 2009 12:12 pm
Thank you!
Your wave shield is working very nicely. Now if only I can get the motor shield to work... I am trying to get an installation piece together in the next couple of weeks. I am hoping to use the motor shield to run some effects w/o luck.
Some examples of previous work:
http://www.absolutearts.com/portfolios/r/rdeisen/
Thanks again!
RE
BTW This is the previous link to the motor shield problems:
viewtopic.php?f=31&t=10619&start=0
richile
