Need help on what relay to use with Arduino for 24vac valve
by argo on Sat Apr 25, 2009 9:20 pm
Need some help on what relay would be best for this application.
I have successfully completed a project using the arduino with xbees. Then I thought wait, now I want to send a signal to an arduino via xbees and tell the arduino to open a sprinkler water valve for 30 minutes. The water valve information says "24vac (50/60Hz , inrush = .4amps, holding = .2amps.
I've seen the diagram on the Arduino site and have seen the adafruit video blog on relays but since my background is in software and I am getting a little bit brave now I would like just a little guidance on what relays I should buy. I've read about solid state vs mechanical, pulse vs always current and so on...
I have 4 sprinkler water valves.
P.S. If anyone knows what relays I should buy for 120v lamps that would be great.
Thanks...
argo
Re: Need help on what relay to use with Arduino for 24vac valve
by adafruit on Sat Apr 25, 2009 9:50 pm
this relay should be OK http://search.digikey.com/scripts/DkSea ... e=PB370-ND
check the xbee relay video and schematic on the blog for ideas. you can control it thru xbees using the arduino. connect the relay to the digital out pin with a transitor buffer and a diode. test it out with low voltage LEDs first of course
and post your progress!
by argo on Sat Apr 25, 2009 10:30 pm
Thanks for the quick reply. I will update my progress.
Like I mentioned before I just needed a little nudge in the right direction. Thanks to this forum I now have my xbees sending info to my arduino+WIZnet which then passes the info to my home php server . I just needed a little help then too.
Thanks again for your products and informational site. Keep up the good work. :D
Argo from Florida....
argo
by adafruit on Mon Apr 27, 2009 11:39 am
great, dont forget to post up your code, photos, etc to show off!
