40 hertz flashing of NeoPixels
by JamesLaderoute on Thu Dec 15, 2016 7:15 pm
I recently read about some research being done in regards to Dementia and light therapy.
See Youtube video: https://www.youtube.com/watch?v=O_p4QWk ... 279.638467
Well, I took my Circuit Playground and wrote this program to make all the NeoPixels flash
at 40 Hz rate (which is the flashing rate mentioned in the video and article).
** The Massachusetts team found shining a strobe light into rodents' eyes encouraged protective cells
** to gobble up the harmful proteins that accumulate in the brain in this type of dementia.
** The perfect rate of flashes was 40 per second - a barely perceptible flicker, four times as fast
** as a disco strobe.
** https://www.youtube.com/watch?v=O_p4QWkE2Ls#t=279.638467
// Flash the light 40 times per second means one flash every 25 milli-seconds
#include <Adafruit_CircuitPlayground.h>
#define HOW_BRIGHT 255 // 0-255, default setting would be 30
#define DELAY_OFF 10 // 10 ms
#define DELAY_ON 11  // 11 ms
  CircuitPlayground.begin();
  CircuitPlayground.setBrightness( HOW_BRIGHT );
      // OFF
      CircuitPlayground.clearPixels();
      delay(DELAY_OFF);
      CircuitPlayground.setPixelColor(0, 255, 255, 255);
      CircuitPlayground.setPixelColor(9, 255, 255, 255);
      CircuitPlayground.setPixelColor(1, 255, 255, 255);
      CircuitPlayground.setPixelColor(8, 255, 255, 255);
      CircuitPlayground.setPixelColor(2, 255, 255, 255);
      CircuitPlayground.setPixelColor(7, 255, 255, 255);
      CircuitPlayground.setPixelColor(3, 255, 255, 255);
      CircuitPlayground.setPixelColor(6, 255, 255, 255);
      CircuitPlayground.setPixelColor(4, 255, 255, 255);
      CircuitPlayground.setPixelColor(5, 255, 255, 255);
      delay(DELAY_ON);
JamesLaderoute
Re: 40 hertz flashing of NeoPixels
by dhalbert on Thu Dec 15, 2016 10:02 pm
I heard about this research on Radiolab: http://www.radiolab.org/story/bringing-gamma-back/. There are related links on the left side of that page.
dhalbert
by adafruit_support_bill on Fri Dec 16, 2016 6:49 am
Interesting research. Maybe we should just develop a computer monitor with a pulsed backlight ;-)
by SimonPG on Sat Aug 24, 2019 6:50 am
Great program by James Laderoute to generate 40 Hz flashing lights in circuit playground for alzheimer treatment. However as a new beginner I cannot get the program to run. I hope that somebody can help
I get an error message "a function definition(void loop) is not allowed here before "{" token ".(please see his program)
I assume I am making an elementary mistake here. Hope someone can help me with this ?
thanks
SimonPG
by adafruit_support_bill on Sat Aug 24, 2019 7:22 am
The program looks correct and I am able to compile it here without problems. Maybe something got corrupted as you copied it to the IDE. Try a fresh copy.
by SimonPG on Sat Aug 24, 2019 7:57 am
Thanks for your reply !
So if I run
void loop() { CircuitPlayground.begin();
 {void loop()
      // OFF
      delay(DELAY_OFF);
      delay(DELAY_ON);
It should work as a loop? But it doesnt and I get the same error message as before?
Last edited by adafruit_support_bill on Sat Aug 24, 2019 10:10 am, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums.
SimonPG
by SimonPG on Sat Aug 24, 2019 8:14 am
Sorry the error message is a little different this time
"expected unqualified-id before '{' token
SimonPG
by adafruit_support_bill on Sat Aug 24, 2019 10:13 am
 {void loop()
You have an '{' before the "void loop()". That is not in the original code.
by SimonPG on Sun Aug 25, 2019 9:29 am
This below in quotes(") is what I ran now- I copied the code directly from the forum message but the error was "expected initializer before 'CircuitPlayground'". Thanks for your patience with a new coder.
  /* Flashinglights
https://forums.adafruit.com/viewtopic.php?f=25&p=541537
 {void loop()
      // OFF
      delay(DELAY_OFF);
      delay(DELAY_ON);
Last edited by adafruit_support_bill on Sun Aug 25, 2019 9:47 am, edited 1 time in total.
SimonPG
by adafruit_support_bill on Sun Aug 25, 2019 9:53 am
Please use [code] tags when posting code to the forums. Click on the [code] button and paste your code between the tags.
Take a close look at the first 4 lines of what you have there. That is not in the forum message - or in the original code from the tutorial.
by SimonPG on Mon Sep 02, 2019 7:50 am
Great ! Thank you. Working perfectly now !
SimonPG
