Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
to clone an arduino mini
by vinnyc on Sun Apr 26, 2009 6:59 am
Hi everybody,
I have a programmed arduino mini and I need another equal one with the same program inside, but I haven't the code anymore. Can I "copy" the program inside the programmed arduino and "paste" it to the second arduino mini with the USBtinyISP AVR Programmer?
If this is possible, what is the simplest way to do it? Do I need a software? How to proceed?
Sorry for the incorrect terms.
Thank you
vinnyc
Re: to clone an arduino mini
by mtbf0 on Sun Apr 26, 2009 12:37 pm
this might snag the program out of flash.
avrdude -c usbtiny -p m168 -U flash:r:program.hex:i
mtbf0
by vinnyc on Sun Apr 26, 2009 2:24 pm
thank you, but can you explain how to use this code? I mean a sort of step by step instruction.
I'm sorry but I have this need and not enough experience. :oops:
vinnyc
by adafruit on Mon Apr 27, 2009 11:36 am
buy a usbtinyisp
read www.ladyada.net/learn/avr
then read everything at http://www.ladyada.net/make/usbtinyisp/
by vinnyc on Thu Apr 30, 2009 10:24 am
only a couple of things more, :oops:
is the code ok as it is posted or I must know the name of the "program".hex?
In wich way avrdude snag out the program from flash? it writes the code in the dos window?
saves an .hex file somewhere? or what? :?
Thank you again
Bye
vinnyc
by adafruit on Thu Apr 30, 2009 11:02 am
it saves it as a .hex in the directory
by mtbf0 on Thu Apr 30, 2009 10:32 pm
vinnyc wrote:only a couple of things more, :oops:
if you use
you get a file called program.hex. if on the other hand you use
avrdude -c usbtiny -p m168 -U flash:r:floccinausinihilipilification.hex:i
you get a file called floccinausinihilipilification.hex. in either case the file will turn up in your current working directory.
mtbf0
by vinnyc on Fri May 01, 2009 9:55 am
thank you very much to both of you for the big help
bye
vinnyc
