Arduino Serial Control Problem (PHP)
by unmanaged on Sun May 03, 2009 8:43 pm
I am trying to use the arduino as a controller for a robot. I need to control it via the web and am trying to use the serial port but it does not seem to work correctly.
Here is the code...
byte incoming1;
byte incoming2;
void setup()
  Serial.begin(9600);
  pinMode(13, OUTPUT);
    if (Serial.available() > 0) {
    incoming1 = Serial.read();
    incoming2 = Serial.read();
           if (incoming1 == 1)
             digitalWrite(13, HIGH);
            delay (900);
          if (incoming2 == 2)
            digitalWrite(13, LOW);
            delay(900);
Here is the PHP code...
<?php
    require("php_serial.class.php");
    $serial = new phpSerial();
    $serial->deviceSet("COM2");
    $serial->confBaudRate(9600); //Baud rate: 9600
    $serial->confParity("none");  //Parity (this is the "N" in "8-N-1")
    $serial->confCharacterLength(8); //Character length (this is the "8" in "8-N-1")
    $serial->confStopBits(1);  //Stop bits (this is the "1" in "8-N-1")
    $serial->confFlowControl("none");
    $serial->deviceOpen();
    $serial->sendMessage("1");
    $serial->deviceClose();
I am not a coder so I am not sure what is up and any help would be much app...
:P
unmanaged
Re: Arduino Serial Control Problem (PHP)
by franklin97355 on Sun May 03, 2009 8:57 pm
I'm not a coder either but it looks like you are sending an ascii 1 (49) and comparing it with a numeric 1 which will never be true.
franklin97355
by unmanaged on Sun May 03, 2009 9:01 pm
I changed the code around to use ascii 49 for '1' and it still is no go...
byte incoming1;
void setup()
  Serial.begin(9600);
           if (incoming1 == 49)
            delay (900);
          if (incoming1 == 50)
            delay(900);
unmanaged
by adafruit on Sun May 03, 2009 10:34 pm
you should, of course, have it print out what it IS getting
by unmanaged on Sun May 03, 2009 10:48 pm
How do I have the serial monitor open and print it out I have tried and the com port is in use....
unmanaged
by unmanaged on Sun May 03, 2009 11:08 pm
if I use the serial monitor to test it it works but when I use php it does not work... any ideas on how to get a clue to what php is doing? I have written what php is sending to a file and it looks fine...
unmanaged
by unmanaged on Mon May 04, 2009 12:49 am
Looks like i compiled todbots code with cygwin and it works ... I had to switch from pin 13 to another pin to make it work correctly ...
unmanaged
