Adafruit_ILI9341 - RST Pin
by ecaits on Mon Jan 09, 2017 1:14 am
As there is written in readme.txt file (https://github.com/adafruit/Adafruit_ILI9341) that these displays use SPI to communicate, 4 or 5 pins are required to interface (RST is optional). During testing of program code, I have found that if I remove the RST pin then the screen become white.
How can I make RST pin optional. Actually, I do not want to use it during interfacing to reduce the number of pin of arduino ethernet board.
Thanks in advance.
ecaits
Re: Adafruit_ILI9341 - RST Pin
by franklin97355 on Mon Jan 09, 2017 1:56 pm
What code are you running for testing?
franklin97355
by ecaits on Tue Jan 10, 2017 12:25 am
I have run graphictest code for testing.
ecaits
by adafruit_support_rick on Tue Jan 10, 2017 10:30 am
It should simply work without the reset line.
Please post some pictures of both sides of the display, showing your soldering and wiring.
by ecaits on Wed Jan 11, 2017 11:58 pm
I have tested and it is working fine.
Thanks for you support.
ecaits
