newb needs help
newb needs help
by skindeepfx on Mon Jan 09, 2017 11:18 am
Good morning everyone
i am pretty new to understanding the Arduino programming and could use some pointers
I am trying to use the 8 led neopixel stick with the RGB sensor TCS34725 and a uno3
i used the chameleon scarf code and it works fine to change colors by pressing the reset button
i know that the code only looks for color at startup
how can i modify the code that the sensor always looks for color changes ?
my instinct tells me it has something to do with a loop and it is probably a very simple solution
Thank you for all of your help
skindeepfx
Re: newb needs help
by adafruit_support_bill on Mon Jan 09, 2017 12:14 pm
You are correct, you need to move some code to the loop.
These lines of code should stay in your setup() function:
  Serial.begin(9600);
  Serial.println("Color View Test!");
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  if (tcs.begin()) {
    Serial.println("Found sensor");
  } else {
    Serial.println("No TCS34725 found ... check your connections");
    while (1); // halt!
  // thanks PhilB for this gamma table!
  // it helps convert RGB colors to what humans see
  for (int i=0; i<256; i++) {
    float x = i;
    x /= 255;
    x = pow(x, 2.5);
    x *= 255;
    gammatable[i] = x;
    //Serial.println(gammatable[i]);
  for (int i=0; i<3; i++){ //this sequence flashes the first pixel three times as a countdown to the color reading.
    strip.setPixelColor (0, strip.Color(188, 188, 188)); //white, but dimmer-- 255 for all three values makes it blinding!
    strip.show();
    delay(1000);
    strip.setPixelColor (0, strip.Color(0, 0, 0));
    strip.show();
    delay(500);
The rest can move to the loop() function so it will take a reading every time through the loop and update the pixels to match.
Re: newb needs help
by skindeepfx on Mon Jan 09, 2017 2:54 pm
thanks for the swift reply
my code looks like this and compiled
but i only get a white flashing led at startup
must have overlooked something
 #include <Wire.h>
#include "Adafruit_TCS34725.h"
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, 6, NEO_GRB + NEO_KHZ800);
// our RGB -> eye-recognized gamma color
byte gammatable[256];
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);
  Serial.begin(9600);
  strip.begin();
  if (tcs.begin()) {
  } else {
    while (1); // halt!
    float x = i;
    x /= 255;
    x = pow(x, 2.5);
    x *= 255;
    gammatable[i] = x;
    strip.show();
    delay(1000);
    strip.show();
    delay(500);
uint16_t clear, red, green, blue;
  tcs.setInterrupt(false);      // turn on LED
  delay(60);  // takes 50ms to read
  tcs.getRawData(&red, &green, &blue, &clear);
  tcs.setInterrupt(true);  // turn off LED
  Serial.print("C:\t"); Serial.print(clear);
  Serial.print("\tR:\t"); Serial.print(red);
  Serial.print("\tG:\t"); Serial.print(green);
  Serial.print("\tB:\t"); Serial.print(blue);
  // Figure out some basic hex code for visualization
  uint32_t sum = red;
  sum += green;
  sum += blue;
  sum += clear;
  float r, g, b;
  r = red; r /= sum;
  g = green; g /= sum;
  b = blue; b /= sum;
  r *= 256; g *= 256; b *= 256;
  Serial.print("\t");
  Serial.print((int)r, HEX); Serial.print((int)g, HEX); Serial.print((int)b, HEX);
  Serial.println();
 // Serial.print((int)r ); Serial.print(" "); Serial.print((int)g);Serial.print(" ");  Serial.println((int)b );
 // colorWipe(strip.Color(gammatable[(int)r], gammatable[(int)g], gammatable[(int)b]), 0);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
Last edited by adafruit_support_bill on Mon Jan 09, 2017 3:14 pm, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums
skindeepfx
Re: newb needs help
by adafruit_support_bill on Mon Jan 09, 2017 3:17 pm
You have the "colorWipe()" at the end of the loop commented out, so it never sets the pixel colors.
Re: newb needs help
by skindeepfx on Mon Jan 09, 2017 4:32 pm
silly me
Thanks for your help it works fine now
skindeepfx
Re: newb needs help
by adafruit_support_bill on Mon Jan 09, 2017 4:58 pm
Great! Thanks for the follow-up.
