trouble using gfx fonts with Arduino Uno
by Gaiastellar on Tue Jan 10, 2017 9:27 am
Hi all,
i've got a ssd1306 oled display (128 x 32) which i've hooked up and got working fine, but i'm trying to use the fonts that are included in the adafruit GFX library, and its not working.
Its a small sketch to tell the time from a rtc module and display it on the oled display, and its working fine with the basic font, but when i add the line:
#include "FreeSans12pt7b";
i get the error message on compilation:
"exit status 1
error compiling for board arduino/genuino uno"
i have about 1000 bytes of dynamic memory left so that shouldn't be a problem i dont think...
i'm not sure what the problem is or what i may be doing wrong.
any help would be appreciated.
many thanks
Gaiastellar
Re: trouble using gfx fonts with Arduino Uno
by caitlinsdad on Tue Jan 10, 2017 3:01 pm
There may be other configuration changes you need to do as described in the guide
https://learn.adafruit.com/adafruit-gfx ... sing-fonts
Good luck.
caitlinsdad
by Gaiastellar on Wed Jan 11, 2017 6:48 am
hi,
thanks..
it says i need to include: #include "FreeMono24pt7b" for example,
but it wont even compile that line - giving me: exit status 1, error compiling for board arduino/genuino uno
ive checked the files are in the right place - it should be able to include it. i'm not sure what this error message means.
thanks
Gaiastellar
by Gaiastellar on Wed Jan 11, 2017 6:53 am
hi,
just a quick update...
such a simple mistake - i forgot to put the .h on the end of the included font file!!!
thanks for your help!
Gaiastellar
