TSL2561 Resolution
TSL2561 Resolution
by Stacy723 on Tue Jan 10, 2017 11:52 pm
Hi, I have bought a TSL2561 to measure very small amount of light.
However, even though the sensor is advertised to have 0.1 LUX as the lower range, the sensor only measures light by 1 LUX and the values between 0.1 to 1 LUX are not being measured (it keeps saying Sensor Overload in low light).
Is this because of the resolution that is set as 1.00?
If it is, could you please tell me how to change it in detail? I do not really know about coding and used a code I downloaded online.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2561_U.h>
   Connections
   Connect SCL to analog 5
   Connect SDA to analog 4
   Connect VDD to 3.3V DC
   Connect GROUND to common ground
   I2C Address
   The address will be different depending on whether you leave
   the ADDR pin floating (addr 0x39), or tie it to ground or vcc.
   The default addess is 0x39, which assumes the ADDR pin is floating
   (not connected to anything).  If you set the ADDR pin high
   or low, use TSL2561_ADDR_HIGH (0x49) or TSL2561_ADDR_LOW
   (0x29) respectively.
   History
   2013/JAN/31  - First version (KTOWN)
Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 12345);
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
  sensor_t sensor;
  tsl.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" lux");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" lux");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" lux");
  Serial.println("");
  delay(500);
    Configures the gain and integration time for the TSL2561
void configureSensor(void)
  // tsl.setGain(TSL2561_GAIN_1X);      /* No gain ... use in bright light to avoid sensor saturation */
  // tsl.setGain(TSL2561_GAIN_16X);     /* 16x gain ... use in low light to boost sensitivity */
  tsl.enableAutoRange(true);            /* Auto-gain ... switches automatically between 1x and 16x */
  /* Changing the integration time gives you better sensor resolution (402ms = 16-bit data) */
  tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);      /* fast but low resolution */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_101MS);  /* medium resolution and speed   */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_402MS);  /* 16-bit data but slowest conversions */
  Serial.print  ("Gain:         "); Serial.println("Auto");
  Serial.print  ("Timing:       "); Serial.println("13 ms");
    Arduino setup function (automatically called at startup)
void setup(void)
  Serial.begin(9600);
  Serial.println("Light Sensor Test"); Serial.println("");
  /* Initialise the sensor */
  if(!tsl.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.print("Ooops, no TSL2561 detected ... Check your wiring or I2C ADDR!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Setup the sensor gain and integration time */
  configureSensor();
  /* We're ready to go! */
  Serial.println("");
    Arduino loop function, called once 'setup' is complete (your own code
    should go here)
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  tsl.getEvent(&event);
  /* Display the results (light is measured in lux) */
  if (event.light)
    Serial.print(event.light); Serial.println(" lux");
  else
    /* If event.light = 0 lux the sensor is probably saturated
       and no reliable data could be generated! */
    Serial.println("Sensor overload");
  delay(250);
Thank you so much
Stacy
Stacy723
Re: TSL2561 Resolution
by franklin97355 on Wed Jan 11, 2017 1:12 am
Please don't double post and follow up in your other post in this section
franklin97355
