To whom it may concern,
I'm trying to connect multiple (Qty 6) BME280 sensors to a TCA9548a multiplexer and having some issues. The aim is to have the ability to output all the temperatures, humidity and pressures from each sensor simultaneous, with basic x-y graph/s. I've tried the adafruit tca9458a document, still have issues. I've tried other examples, with no success. Any help will be appreciated.
Regards,
Viktor
TCA9548a Multiplexer with multiple (qty 6) BME280's
- ViktorArmani
- Franklin97355
Re: TCA9548a Multiplexer with multiple (qty 6) BME280's
What code are you using and what are you getting for results?
- ViktorArmani
ok
- Franklin97355
That code has too many parts combined and would not compile. Please make sure that you post the exact code you are using
- ViktorArmani
The following code was from georgeklinger forum page, added the humidity reading, however, when i run the i2cscanner it doesn't pick up the other sensor. At the moment i only have two sensors connected to the TCA9548a multiplexer (see image). I'm aiming to get up to 6 connected.
* TCA9548 I2CScanner.pde -- I2C bus scanner for Arduino
* Based on code c. 2009, Tod E. Kurt, http://todbot.com/blog/
#include "Wire.h"
extern "C" {
#include "utility/twi.h" // from Wire library, so we can do bus scanning
#include <Wire.h>
#include <Adafruit_BME280.h>
#include <Adafruit_Sensor.h>
#define TCAADDR 0x70
Adafruit_BME280 bmp[8]; // I2C
boolean portarray[8] = {true, true, true, true, true, true, true, true};
float temperature[8];
float humidity [8];
float pressure[8];
uint8_t j;
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
void setup(void)
while (!Serial);
Wire.begin();
Serial.begin(9600);
Serial.println("\nTCAScanner ready!");
for (uint8_t t=0; t<8; t++) {
tcaselect(t);
Serial.print("TCA Port #"); Serial.println(t);
for (uint8_t addr = 0; addr<=127; addr++) {
if (addr == TCAADDR) continue;
uint8_t data;
if (! twi_writeTo(addr, &data, 0, 1, 1)) {
Serial.print("Found I2C 0x"); Serial.println(addr, HEX);
Serial.println("\ndone");
delay(2000);
Serial.println("BMP280 Multiplex Initialization"); Serial.println("");
for (uint8_t port = 0; port<=7; port++) {
tcaselect(port);
if(!bmp[port].begin()){
Serial.print("No BMP280 detected at port ");Serial.println(port);
portarray[port] = false;
void loop(void)
for (j = 0; j<=7; j++) {
if (portarray[j]) {
tcaselect(j);
temperature[j] = bmp[j].readTemperature();
humidity[j] = bmp[j].readHumidity();
pressure[j] = bmp[j].readPressure();
Serial.print("Port "); Serial.print(j);
Serial.print(" Temperature = ");
Serial.print(temperature[j]);
Serial.println(" C");
Serial.print(" Humidity = ");
Serial.print(humidity[j]);
Serial.println(" %");
Serial.print(" Pressure = ");
Serial.print(pressure[j]);
Serial.println(" Pa");
Serial.println("");
delay(1650);
- Untitled.gif (175.61 KiB) Viewed 866 times
Reason: Please use [code] tags when posting code or logs to the forums by clicking the </> button above the reply box and pasting your code between the tags created.
