My knowledge is limited, but I've managed to use existing sketches on 2 previous paintings. I can play with values, make simple changes to suit.
For the current painting I'm using a sketch from this forum. Here's a link to the video:
https://youtu.be/JGHqbrPHJI0
Here's the code: /**
* Quick commented example of one way you could change LEDs down a NeoPixel strip
* starting at any pixel on the strip (going outwords), where the next LED begins
* fading on after the previous reaches 50%.
* @author SeiRruf MalaWolSki
* @date Sept. 13, 2014
* Free to use and distribute
#include <Adafruit_NeoPixel.h> // NeoPixel Library
#define NeoPixel_Pin 6
#define NeoPixels 140
Adafruit_NeoPixel strip = Adafruit_NeoPixel ( NeoPixels, NeoPixel_Pin, NEO_GRB + NEO_KHZ800 );
// Gamma correction improves appearance of midrange colors
const uint8_t gamma[] PROGMEM = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
void setup ()
strip.begin ();
strip.show ();
strip.setBrightness (220); // 0-255, 255== max brightness
randomSeed ( analogRead(0) ); //ensure always random (optional)
//trying to blend colors from daybreak to sunset
//1st color purple
fadeChaseFill (40, strip.Color (140, 0, 240), 0 );//purple
//delay 1 second before starting next color
delay ( 5 );
void loop ()
fadeChaseFill (43, strip.Color (120,0,200), strip.Color (0,0,0) );
//delay ( 5 );//lt purple
fadeChaseFill (49, strip.Color (100,20,180 ), strip.Color (120,0,200) );
fadeChaseFill (56, strip.Color (13,100,220), strip.Color (100,0,180) );
//delay ( 5 );
//start at a random pixel, new color is blue, prevoius is green
fadeChaseFill (63, strip.Color (160,84,120), strip.Color (13,78,241) );
delay ( 5 );
// light yellow
fadeChaseFill (70, strip.Color (225,100,160), strip.Color (127,127,127) );
delay ( 5 );
//white
fadeChaseFill (80, strip.Color (13,100,220), strip.Color (255,100,160) );
delay(5); //lt blue gr
fadeChaseFill (90, strip.Color (140,0,240), strip.Color (120,0,220 ));
delay ( 5 );// lite purple
fadeChaseFill (100, strip.Color (120,0,200 ), strip.Color ( 0,0,0 ) );
//delay ( 1000 );
fadeChaseFill (30, strip.Color (0,0,0), strip.Color (255,100,160) );
delay ( 5 );
void fadeChaseFill ( uint8_t startPixel, uint32_t color, uint32_t pColor )
//for each pixel
for ( uint8_t i=0; i<strip.numPixels()+2; i++ ) { //buffer added (+2 pixels)
//level of color (up to 255, which is max brightness)
for ( float level=127; level<255; level+=1 ) {
//don't draw pixels if we're outside of our limit (with buffer pixel)
if ( startPixel+i < strip.numPixels()+1 ) {
//next pixel 0->127
strip.setPixelColor ( startPixel+i,
colorTween (
opacity ( color, (level-127.0)/255.0 ),
pColor,
level-127.0
//there is no previous pixel if we're starting at 0.
if ( i != 0 ) {
//last pixel 127->255
strip.setPixelColor ( (startPixel-1+i),
opacity ( color, level/255.0 )
if ( startPixel-i >= -1 ) {
//next pixel 0->127
strip.setPixelColor ( startPixel-i,
colorTween (
pColor,
level-127.0
if ( i != 0 ) {
strip.setPixelColor ( (startPixel+1-i),
strip.show ();
delay ( 1 ); //CHANGE THIS TO SPEED UP/SLOW DOWN YOUR ANIMATION
* splitColor() - Receive a uint32_t value, and spread into bits.
uint8_t splitColor ( uint32_t c, char value )
* Quick code explanation:
* 'x >> y' shifts the given var (x) over (y) bytes.
* Since we're dealing with a 24byte color, in order red, green, blue,
* Represented as 11111111 11111111 11111111 (assuming 255,255,255)
* bit placement: 23-22-21-20-19-18-17-16, 15-14-13-12-11-10-9-8, 7-6-5-4-3-2-1-0
* We want to take the first 16-23 bytes and call them red, and so on.
* declaring the return value as uint8_t ensures we receive 0-255 expected value.
switch ( value ) {
case 'r': return (uint8_t)(c >> 16);
case 'g': return (uint8_t)(c >> 8);
case 'b': return (uint8_t)(c >> 0);
default: return 0;
//fade c1 over c2
uint32_t colorTween ( uint32_t c1, uint32_t c2, float fadeRate )
//variables should never exceed one byte, so mark them as uint8_t.
uint8_t r, g, b, r1, g1, b1, r2, g2, b2;
//split our new color
r1 = splitColor ( c1, 'r' );
g1 = splitColor ( c1, 'g' );
b1 = splitColor ( c1, 'b' );
//split our old color
r2 = splitColor ( c2, 'r' );
g2 = splitColor ( c2, 'g' );
b2 = splitColor ( c2, 'b' );
//mix the color
r = r1 + ((float)r2*(1-(fadeRate/127.0)));
g = g1 + ((float)g2*(1-(fadeRate/127.0)));
b = b1 + ((float)b2*(1-(fadeRate/127.0)));
//assemble & send it on its way
return (
strip.Color ( r, g, b )
// dim current given color. O can only range from 0.0 to 1.0
uint32_t opacity ( uint32_t c, float o )
* To dim a color, you must split it's values individually. That's already done above.
* Now we multiply each one by the value we want dimmed.
* In this case, say 100%. o =(100/100)=1. 255*1 = 255. Full brightness, yay!
* How about 0%? o =(0/100)=0. 255*0 = 0. No brightness, aww..
* How about 50%? o =(50/100)=0.50. 255*0.50=178. Only half on, woo!
return strip.Color (
pgm_read_byte ( &gamma[int(splitColor(c,'r') * o)] ),
pgm_read_byte ( &gamma[int(splitColor(c,'g') * 2)] ),
pgm_read_byte ( &gamma[int(splitColor(c,'b') * o)] )
2 things that I like about this sketch: 1)the sequence of lights can start at any point along the strip, and goes outward in both directions.
2) The neopixel colors are fantastic! Many possibilities using the 2 sets of colors.
In real time, the entire sketch takes about 8 minutes. Each sequence of lights takes about 41 seconds, & there's a delay of 33 seconds. I'm guessing that the delay is because the arduino has to get through a lot of code. So here's my question, is there a straightforward way, for me, of shortening the delay? Can you explain, perhaps, what part of the code are these dual colors dependent on? It'd like to use them again. Thank you
