I have recently been running into problems using the K-type thermocouple and Max 31855 breakout board. I am using the thermocoupes to measure the temperature inside an agarose gel, you can imagine it like stiff jello. This is an aqueous environment.
The first two days I used my setup I did not run into any problems, but now when I submerge 4 thermocouples into the gel, I am not getting a reading. The thermocouples record temperature just fine in air or water so I don't believe this is a wiring issue. I have also noticed that if I submerge 1 thermocouple in the gel and leave the remaining three in air I receive temperature measurements from all 4 thermocouples.
I'm quite confused as to why this is happening, could they have corroded in this short a time? Any help would be much appreciated.
Problem with K Type Thermocouple
- Franklin97355
Re: Problem with K Type Thermocouple
It sounds like your gel is conductive and the signals are getting shorted out. You may need to insulate the junction and cable inside the gel.
Insulated probes can be found at most industrial suppliers. Omega Engineering probably has the widest selection. Any K-type probe will work with the Max 31855.
