First time poster here. I'm using the Radiohead library for two RFM69HCW radios. I've got one hooked up to an Arduino Micro and the other hooked up to an Uno. The micro works perfectly with the radio. The Uno does not. Even the most basic raw transmit and raw receive examples provided for the Feather do not work.
The serial monitor for the micro prints exactly what the code should, regardless of whether it's acting as the transmitter or receiver. The Uno will display a few lines of text confirming the initialization and one acknowledgement, but then just prints garbage. It displays the same behavior regardless of whether it's the transmitter or receiver. To me, it looks like they are communicating with each other, it's just that whenever the Uno receives a message, it doesn't print properly.
I've triple checked my wiring on both units and have tried swapping around the radios, but I'm shakiest on the coding side of things.
RFM69HCW on Arduino Uno
- hspooner
- Uno Receiver.PNG (12.51 KiB) Viewed 872 times
- Uno Transmitter.PNG (15.31 KiB) Viewed 872 times
- Micro Receiver.PNG (19.83 KiB) Viewed 872 times
- adafruit_support_rick
Re: RFM69HCW on Arduino Uno
Post some pictures of your wiring and soldering.
Post the code you're running on the Uno
- hspooner
The example Uno receiver code. The only modification I made was to comment out the part defining LED as pin 13: this radio requires pin 13 for CLK.
The Micro transmitter code:
#include <SPI.h>
#include <RH_RF69.h>
/************ Radio Setup ***************/
#define RF69_FREQ 915.0
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
#define RFM69_CS 8
#define RFM69_INT 7
#define RFM69_RST 4
#define LED 13
#endif
#if defined(ARDUINO_SAMD_FEATHER_M0) // Feather M0 w/Radio
#define RFM69_CS 8
#define RFM69_INT 3
#define RFM69_RST 4
#define LED 13
#endif
#if defined (__AVR_ATmega328P__) // Feather 328P w/wing
#define RFM69_INT 3 //
#define RFM69_CS 4 //
#define RFM69_RST 2 // "A"
//#define LED 13
#endif
#if defined(ESP8266) // ESP8266 feather w/wing
#define RFM69_CS 2 // "E"
#define RFM69_IRQ 15 // "B"
#define RFM69_RST 16 // "D"
#define LED 0
#endif
#if defined(ESP32) // ESP32 feather w/wing
#define RFM69_RST 13 // same as LED
#define RFM69_CS 33 // "B"
#define RFM69_INT 27 // "A"
#define LED 13
#endif
/* Teensy 3.x w/wing
#define RFM69_RST 9 // "A"
#define RFM69_CS 10 // "B"
#define RFM69_IRQ 4 // "C"
#define RFM69_IRQN digitalPinToInterrupt(RFM69_IRQ )
/* WICED Feather w/wing
#define RFM69_RST PA4 // "A"
#define RFM69_CS PB4 // "B"
#define RFM69_IRQ PA15 // "C"
#define RFM69_IRQN RFM69_IRQ
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;
void setup()
Serial.begin(115200);
//while (!Serial) { delay(1); }
pinMode(LED, OUTPUT);
pinMode(RFM69_RST, OUTPUT);
digitalWrite(RFM69_RST, LOW);
Serial.println("Feather RFM69 RX Test!");
Serial.println();
// manual reset
digitalWrite(RFM69_RST, HIGH);
delay(10);
delay(10);
if (!rf69.init()) {
Serial.println("RFM69 radio init failed");
while (1);
Serial.println("RFM69 radio init OK!");
if (!rf69.setFrequency(RF69_FREQ)) {
Serial.println("setFrequency failed");
rf69.setTxPower(20, true); // range from 14-20 for power, 2nd arg must be true for 69HCW
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
rf69.setEncryptionKey(key);
//pinMode(LED, OUTPUT);
Serial.print("RFM69 radio @"); Serial.print((int)RF69_FREQ); Serial.println(" MHz");
if (rf69.available()) {
uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf69.recv(buf, &len)) {
if (!len) return;
buf[len] = 0;
Serial.print("Received [");
Serial.print(len);
Serial.print("]: ");
Serial.println((char*)buf);
Serial.print("RSSI: ");
Serial.println(rf69.lastRssi(), DEC);
if (strstr((char *)buf, "Hello World")) {
uint8_t data[] = "And hello back to you";
rf69.send(data, sizeof(data));
rf69.waitPacketSent();
Serial.println("Sent a reply");
//Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
} else {
Serial.println("Receive failed");
void Blink(byte PIN, byte DELAY_MS, byte loops) {
for (byte i=0; i<loops; i++) {
digitalWrite(PIN,HIGH);
delay(DELAY_MS);
digitalWrite(PIN,LOW);
delay(DELAY_MS);
#include <SPI.h>
#define RFM69_CS 8
#define RFM69_INT 7
#define RFM69_RST 4
#define LED 13
#endif
#define RFM69_CS 8
#define RFM69_INT 3
#define RFM69_RST 4
#define LED 13
#endif
#define LED 13
#endif
#define LED 0
#endif
#define LED 13
#endif
void setup()
Serial.println("Feather RFM69 TX Test!");
Serial.println();
// manual reset
delay(10);
delay(10);
if (!rf69.init()) {
while (1);
delay(1000);
char radiopacket[20] = "Hello World #";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending "); Serial.println(radiopacket);
rf69.send((uint8_t *)radiopacket, strlen(radiopacket));
if (rf69.waitAvailableTimeout(500)) {
Serial.print("Got a reply: ");
Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks
} else {
} else {
Serial.println("No reply, is another RFM69 listening?");
delay(DELAY_MS);
delay(DELAY_MS);
- Uno.JPG (870.79 KiB) Viewed 849 times
- Micro.JPG (896.42 KiB) Viewed 849 times
I don't see anything wrong in the pictures.
I'm wondering if it's a problem with your Uno. You'll notice that it's dropped characters in serial monitor even before the garbage shows up.
Like, you see "K!" instead of "RFM69 radio init OK!"
Have you tried swapping the modules between the Uno and the Micro? Have you tried swapping TX and RX between the Micro and the Uno?
- hspooner
Yes, I've tried swapping the radios around and I've tried the Uno as both the transmitter and receiver. Doesn't make a difference what role it's playing: the reply message is always garbled.
It's weird because I've used this board for several other things and it seems to be ok. It will print other sensor data to the serial monitor just fine.
Would it be worthwhile to try a new board?
Seems like it can't have anything to do with the radios. If you've swapped the radios, and you've swapped the RX TX code, and the problem always stays with the Uno, then the Uno must be the problem.
I suppose you could try lowering the baud rate for Serial Monitor. Try 9600.
I suppose it might also be the USB cable on the Uno. You could try replacing that.
- jonathanleistiko
FWIW: I had a similar problem and lowering the baud rate worked for me.
- dustmodebros
Getting the same issue, baud rate is already at 9600...
jonathanleistiko wrote:FWIW: I had a similar problem and lowering the baud rate worked for me.
Feather RFM69 TX TeK!
RFM69 radio @915 MHz
Sending Hello World #0
Sending Hello World #1
⸮K⸮⸮⸮⸮⸮⸮⸮⸮⸮Z⸮⸮<⸮
⸮⸮<_⸮
N<⸮⸮⸮⸮⸮⸮қ⸮L=u⸮⸮⸮⸮<⸮9⸮⸮⸮9⸮⸮Z⸮⸮\⸮Z⸮⸮\⸮⸮⸮⸮NΖ⸮⸮⸮_⸮⸮
- dustmodebros
NEVER MINDdustmodebros wrote:Getting the same issue, baud rate is already at 9600...jonathanleistiko wrote:FWIW: I had a similar problem and lowering the baud rate worked for me.Code: Select all
Feather RFM69 TX TeK! RFM69 radio @915 MHz Sending Hello World #0 No reply, is another RFM69 listening? Sending Hello World #1 ⸮K⸮⸮⸮⸮⸮⸮⸮⸮⸮Z⸮⸮<⸮ ⸮⸮<_⸮ N<⸮⸮⸮⸮⸮⸮қ⸮L=u⸮⸮⸮⸮<⸮9⸮⸮⸮9⸮⸮Z⸮⸮\⸮Z⸮⸮\⸮⸮⸮⸮NΖ⸮⸮⸮_⸮⸮ ⸮
baud rate was set as 115200 for some reason...
