Just received my Metro Mini a few days ago. Had some driver problems initially, but a combination of the FTDI SiLabs drivers while setting the IDE to the normal Uno board seemed to work fine when uploading a blink sketch. However, after changing from what I can remember nothing, the board has stopped responding. The blink sketch does not run when I give it power, but the green power LED is constantly lit. When I try to upload any sketches, I can faintly see the RX LED flash for a second but then stop. After a few retries the IDE gives this error:
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Any ideas?
