Adafruit Fona 808 error: couldn't find fona
by architmuchhal on Wed Jun 07, 2017 11:43 am
Serial Com2
Serial Com1
I am using Espressif ESp32 along with Adafruit FONA808. I am able to compile the code and upload too.
After uploading, I get a message on Serial Com as -
Couldn't find FONA
I have set the baud rate as 115200 and also attached a battery. I am attaching the screenshots of the Serial Com.
Any suggestions are welcome.
architmuchhal
Re: Adafruit Fona 808 error: couldn't find fona
by adafruit_support_rick on Mon Jun 12, 2017 7:53 am
The FONA runs at 4800 baud, not 115200
by Cpatekiii on Mon May 13, 2019 9:51 pm
I am having the same problem.... Baud on serial is set to 4800....still can't find the FONA 808. Tried ESP32 software serial and hardware serial still no joy.... Tried multiple combinations of GPIO pins as well.... What gives?
Cpatekiii
by cpatek on Thu May 16, 2019 7:06 am
Well I finally found the issue on my own....the serial port listed in the example for the fona will not work for the ESP32. You must change the hardware serial port to Serial2 and use pins 16 & 17.
instead of:
HardwareSerial *fonaSerial = &Serial1;
use
HardwareSerial *fonaSerial = &Serial2;
I was never able to get SoftwareSerial to work properly......even using the EspSoftwareSerial versions. but think it was due to something I was doing wrong as I am sure they work.
cpatek
