I just downloaded the Arduino motor-shield library. When I attempt to compile the DCMotorTest example in the library, I get "Error compiling" with the following:
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master C:\Users\owner\AppData\Local\Temp\build9070234571449194604.tmp\AdafruitMotorShield_Two_Motors_Test_20June2017.cpp -o C:\Users\owner\AppData\Local\Temp\build9070234571449194604.tmp\AdafruitMotorShield_Two_Motors_Test_20June2017.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master -IC:\Program Files (x86)\Arduino\libraries\Wire\utility C:\Program Files (x86)\Arduino\libraries\Wire\Wire.cpp -o C:\Users\owner\AppData\Local\Temp\build9070234571449194604.tmp\Wire\Wire.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master -IC:\Program Files (x86)\Arduino\libraries\Wire\utility C:\Program Files (x86)\Arduino\libraries\Wire\utility\twi.c -o C:\Users\owner\AppData\Local\Temp\build9070234571449194604.tmp\Wire\utility\twi.c.o
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\utility C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp -o C:\Users\owner\AppData\Local\Temp\build9070234571449194604.tmp\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp.o
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp: In member function 'void Adafruit_StepperMotor::step(uint16_t, uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp:237: error: 'yield' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp: In member function 'uint8_t Adafruit_StepperMotor::onestep(uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp:242: warning: unused variable 'a'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp:242: warning: unused variable 'b'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp:242: warning: unused variable 'c'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Motor_Shield_V2_Library-master\Adafruit_MotorShield.cpp:242: warning: unused variable 'd'
Can you help me?
Thank you.
Ted
