Multiple MAX31865
Multiple MAX31865
by clintp on Mon Jul 24, 2017 4:34 pm
I am trying to Connect four MAX31865 break out boards to an arduino MEGA. I understand that each board needs to have its own CS pin assigned, however I have not be able to implement that. How would one go about making multiple boards work at the same time?
clintp
Re: Multiple MAX31865
by adafruit_support_bill on Mon Jul 24, 2017 4:37 pm
Connect the CS pin for each board to a different pin. The clock and data pins can be shared. In the code, for each instance of Adafruit_MAX31865, specify the pins you are using.
by clintp on Mon Jul 24, 2017 5:11 pm
Thank you, I am getting an error stating no matching function for call to ''Adafruit_MAX31865::Adafruit_MAX31865(int, int)'
Adafruit_MAX31865 max = Adafruit_MAX31865(53,45);
here is the code I am trying to use.
#include <Adafruit_MAX31865.h>
#include "SPI.h"
// use hardware SPI, just pass in the CS pin
// The value of the Rref resistor. Use 430.0!
#define RREF 430.0
  Serial.begin(115200);
SPI.begin();
  max.begin(MAX31865_4WIRE);  // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd = max.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio,8);
  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
  Serial.print("Temperature = "); Serial.println(max.temperature(100, RREF));
  // Check and print any faults
  uint8_t fault = max.readFault();
  Serial.println();
  delay(1000);
Last edited by adafruit_support_bill on Mon Jul 24, 2017 5:17 pm, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums.
clintp
by adafruit_support_bill on Mon Jul 24, 2017 5:20 pm
You are only defining one instance of the sensor. You can't have one sensor with 2 CS pins. You need to define one instance for each sensor you are connecting:
Adafruit_MAX31865 max_1 = Adafruit_MAX31865(53);
Adafruit_MAX31865 max_2 = Adafruit_MAX31865(45);
by clintp on Mon Jul 24, 2017 5:43 pm
I tried to implement the code like in your example however I keep getting different errors depending on how I change the code. It only seems to work in its original format. which I will include below. I took this code from get Hub there was a link from the adafruit tutorial. So I don't really understand how the code works.
// Use software SPI: CS, DI, DO, CLK
//Adafruit_MAX31865 max = A (37, 39, 41, 43);
 //use hardware SPI, just pass in the CS pin
Adafruit_MAX31865 max = Adafruit_MAX31865(54);
#define RREF 430.0
  float ratio = rtd;
  ratio /= 32768;
  Serial.println();
  delay(1000);
I added the _1 and _2 to like in your example and received the following error.
C:\Users\Clint\Desktop\Packless\arduino\multipal_sensors_rtd\multipal_sensors_rtd.ino: In function 'void setup()':
multipal_sensors_rtd:14: error: 'max' was not declared in this scope
C:\Users\Clint\Desktop\Packless\arduino\multipal_sensors_rtd\multipal_sensors_rtd.ino: In function 'void loop()':
multipal_sensors_rtd:18: error: 'max' was not declared in this scope
exit status 1
Again thank you for the help.
please use [code] tags when submitting code to the forums.
clintp
by adafruit_support_bill on Mon Jul 24, 2017 6:02 pm
Please use [ code ] tags when submitting code to the forums.
You no longer have a Adafruit_MAX31865 named "max". You have two of them named "max_1" and "max_2".
To use those sensors in your code, you need to reference them separately. And reference them by the names you have assigned them.
becomes:
  max_1.begin(MAX31865_4WIRE);
  max_2.begin(MAX31865_4WIRE);
by clintp on Fri Jul 28, 2017 11:21 am
I am still having errors occur. I still don't understand how to name the max functions individually. Whenever I try to they turn from orange to black. I understand the max function is used to compare two numbers and finds the maximum which in this case i'm guessing is the resistance between the wire pairs. I am also wondering if because I am renaming things if it will affect the ability to use the library used to run one board.
This is the code I am trying to use now. The error I am getting says 'class Adafruit_MAX31865' has no member named 'temperature1'
How can I fix this?
#include "SPI.h"
Adafruit_MAX31865 max_2= Adafruit_MAX31865(46);
#define RREF 430.0
SPI.begin();
  max_1.begin(MAX31865_4WIRE);  // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd1 = max_1.readRTD();
  uint16_t rtd2 = max_2.readRTD();
  Serial.print("RTD value1: "); Serial.println(rtd1);
    Serial.print("RTD value2: "); Serial.println(rtd2);
  float ratio1 = rtd1;
    float ratio2 = rtd2;
  ratio1 /= 32768;
    ratio2 /= 32768;
  Serial.print("Resistance1 = "); Serial.println(RREF*ratio1,8);
    Serial.print("Resistance2 = "); Serial.println(RREF*ratio2,8);
  Serial.print("Temperature1 = "); Serial.println(max_1.temperature1(100, RREF));
    Serial.print("Temperature2 = "); Serial.println(max_2.temperature2(100, RREF));
  uint8_t fault1 = max_1.readFault1();
  uint8_t fault2 = max_2.readFault2();
  Serial.println();
  delay(1000);
Thank you
Also I don't understand what was meant by "tags when submitting code to the forums."
clintp
by adafruit_support_bill on Fri Jul 28, 2017 12:02 pm
Press the [code] button and paste your code between the tags.
If you are getting compile errors, please post the exact text of the error. That will tell you which line the error was detected on and what the compiler does not like.
by clintp on Fri Jul 28, 2017 12:03 pm
#include "SPI.h"
#define RREF 430.0
SPI.begin();
  ratio1 /= 32768;
    ratio2 /= 32768;
  Serial.println();
  delay(1000);
The compiling error is happening with
I think it is happening because the library im trying to use doesn't have temperature1 only a single temperature. Can I modify the code some how or will I need to wright my own code to be able to use more than one board?
clintp
by adafruit_support_bill on Fri Jul 28, 2017 12:15 pm
by clintp on Fri Jul 28, 2017 12:21 pm
Sorry I and kind of new to all of this, you are referring to the text from the error messages box correct? If so this is what I am getting.
multipal_sensors_rtd:31: error: 'class Adafruit_MAX31865' has no member named 'temperature1'
multipal_sensors_rtd:32: error: 'class Adafruit_MAX31865' has no member named 'temperature2'
multipal_sensors_rtd:35: error: 'class Adafruit_MAX31865' has no member named 'readFault1'
multipal_sensors_rtd:36: error: 'class Adafruit_MAX31865' has no member named 'readFault2'
exit status 1
clintp
by adafruit_support_bill on Fri Jul 28, 2017 12:44 pm
You are trying to call a function that does not exist. Adafruit_MAX31865 does not have a member function named 'temperature1' or 'temperature2'. But it does have a member function named 'temperature'. That is what you should be using.
by clintp on Fri Jul 28, 2017 12:52 pm
That fixed it. Thank you for all the help.
clintp
by kkralicek on Mon Dec 31, 2018 8:21 am
Hello CLINTP,
Can you please post your final code for the MAX31865's that was working for you? I am a newby as well and am doing a board with 5 max31865's on it. So your final code would help me greatly.
TIA!!!
kkralicek
