Datasheet for Monochrome 1.3" 128x64 OLED graphic display is
- akotlarsky
Datasheet with correct mechanical drawings is NOT provided for the Monochrome 1.3" 128x64 OLED graphic display on your web-site (the datasheet on your web-site is referring to 0.96" display, which obviously has different mechanical characteristics). Please provide data sheet with correct mechanical drawings for the 1.3" part.
- adafruit_support_carter
Re: Datasheet for Monochrome 1.3" 128x64 OLED graphic displa
Can you provide a link to the page where you're not finding it? Also, are you looking for mechanical characteristics of just the OLED display, or the entire breakout board?
- akotlarsky
The UG-2864HSWEG01 Datasheet (https://cdn-shop.adafruit.com/datasheet ... SWEG01.pdf) describes 0.96" display, not 1.3". I am asking specifically about mechanical drawings of the entire 1.3" module. If you can deliver the correct specification for the entire 1.3" module, which would include the correct mechanical drawings, it would be even better. But at this time, I specifically need just mechanical drawings for the entire 1.3" module, which I have purchased from Adafruit, ASAP.
There is some dimensional information at the bottom of the product page:
https://www.adafruit.com/product/938
and the CAD files for the entire board are here:
https://github.com/adafruit/Adafruit-1. ... o-OLED-PCB
with some renderings also here:
https://learn.adafruit.com/monochrome-o ... dot-3-oled
I will ask about the datasheet.
- adafruit2
yeah you dont need the datasheet, you just want the documents here:
- akotlarsky
- ImSebastian
Hey Folks -
I'm also in need of accurate drawings here. I want to create a cutout in a panel the same size as the LCD - the links provided show the mounting holes just fine, but there is ambiguity as to where the screen edge is. I realize I can't mount the LCD with the screen protruding out because of the connections on the bottom (near the "U" in the PCB) but I'd like the hole to reveal the screen.
The link ( https://learn.adafruit.com/monochrome-o ... dot-3-oled ) doesn't accurately show the relationship of the screen to the mounting holes.
Any help would be appreciated!
Sebastian
Sebastian
The screens are held on with tape. Their location is not super precise. If your tolerance is super tight, it's probably best to get the actual product and work from there.
You can also open the CAD files in Eagle and inspect all the dimensions there.
- adafruit2
the diagram shows a dashed line of the visible display, and its dimensioned enough you can position it, just add numbers or subtract em
- ImSebastian
Maybe I am missing something obvious? The dimensions indicate the dotted line is 0.57" (0.82" - 0.25") x 1.15" (1.27" - 0.12"), but the product description says it's 0.9" x 1.4"adafruit2 wrote:the diagram shows a dashed line of the visible display, and its dimensioned enough you can position it, just add numbers or subtract em
Thanks for the replies!
- adafruit2
its 1.3" diagonal so the dotted lines are correct - thats the visible part of the display
