I am using a myFile.print statement and it works in the set up but not the loop. I had some code that worked fine when I used the Metro MO Express with a data logging shield but when I switched to the Feather MO adalogger the myFile.print statement works in the setup but not in the loop. To demonstrate this, I just modified the SD example code.
#include <SPI.h>
#include <SD.h>
File myFile;
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("Datalog.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
} else {
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("Datalog.txt");
if (myFile) {
Serial.println("Datalog.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
} else {
myFile.println("test");
myFile.close();
delay(1000);
Serial.print("loop is running");
Can somebody tell me why the myFile.print statement does not work in the loop? All I get is the "testing 1, 2, 3." line.
