Trinket Pro - Can't find USBtiny device
by fitsum on Mon Nov 13, 2017 2:50 pm
I have a Trinket Pro 5V/16MHz connected over USB on OSX that gives the following error when I try to upload blink sketch via Arduino IDE
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
I've retried immediately after pressing reset
I'm using a USB cable through a USB2 hub that came with a gopro so I'm certain it's data cable not charge only
fitsum
Re: Trinket Pro - Can't find USBtiny device
by franklin97355 on Mon Nov 13, 2017 4:40 pm
What board do you have selected in the boards menu and do you have a com port selected? Set the compile and upload options to verbose in the preferences and post the entire output for us to see. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
franklin97355
by fitsum on Mon Nov 13, 2017 9:48 pm
Franklin,
board: Pro Trinket 5V/16MHz(USB) board
COM port: none selected
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/fitsum/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/fitsum/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/fitsum/Documents/Arduino/libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10805 -build-path /var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063 -warnings=all -build-cache /var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_cache_284518 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/fitsum/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/fitsum/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/fitsum/Documents/Arduino/libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10805 -build-path /var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063 -warnings=all -build-cache /var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_cache_284518 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'protrinket5' from platform in folder: /Users/fitsum/Library/Arduino15/packages/adafruit/hardware/avr/1.4.9
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/sketch/Blink.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/sketch/Blink.ino.cpp" -o "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/sketch/Blink.ino.cpp" -o "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/sketch/Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.elf" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/sketch/Blink.ino.cpp.o" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/../arduino_cache_284518/core/core_adafruit_avr_protrinket5_51f02b7210b938436b779d1c032618e1.a" "-L/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063" -lm
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.elf" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.eep"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom  "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.elf" "/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.hex"
Sketch uses 928 bytes (3%) of program storage space. Maximum is 28672 bytes.
Global variables use 9 bytes of dynamic memory.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:/var/folders/j4/11tyvh4s24s7vmy2jdn2xgsr0000gn/T/arduino_build_870063/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/fitsum/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbtiny
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
fitsum
by franklin97355 on Mon Nov 13, 2017 11:35 pm
Do you have the USBtinyISP selected as the programmer? https://learn.adafruit.com/introducing-pro-trinket#setting-up-arduino-ide
franklin97355
by fitsum on Tue Nov 14, 2017 12:08 am
I do
fitsum
by fitsum on Wed Nov 15, 2017 7:40 pm
halp me guys please
fitsum
by franklin97355 on Wed Nov 15, 2017 8:16 pm
Alright, let's try replacing it. Please contact support@adafruit.com with a link to this topic and they will get you a replacement Trinket Pro.
franklin97355
by fitsum on Thu Nov 16, 2017 1:23 am
ok thanks. I'm going to see if I can get it running from one of my raspberry pis as well before I do and notify
fitsum
by fitsum on Fri Nov 17, 2017 9:04 pm
@franklin97355
can you advise on Arduino 2.1 on raspberry pi? Under Tools, Serial Port is greyed out and I don't get a board manager from the Board submenu.
I get the following error
Serial port "COM1" not found. Did you select the right one from the Tools > Serial ....
fitsum
