water pump with LCD
water pump with LCD
by Pashgen on Thu Nov 16, 2017 11:10 pm
Hi Everyone,
I am building watering system. Trying to show sensor readings on LCD. But no luck so far
Could you please check my code. how can I show soil moisture value on LCD?
I also wonder if I can show in %, for instance - very wet - show 100% on LCD, dry 0%, yeah, something like that
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,20,4);
int PUMP = 13;
int sensor = 8;
int val;
const int DigitalInPin = 8;
int sensorValue = digitalRead(8);
  pinMode(13,OUTPUT);
  pinMode(8,INPUT);
lcd.init();                      // initialize the lcd
lcd.init();
delay(100);
   val = digitalRead(8);
  if(val ==LOW)
  digitalWrite(13,LOW);
  else
  digitalWrite(13,HIGH);
  delay(400);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Soil Moisture:");
lcd.setCursor(0, 1);
lcd.print(sensorValue);
[img][/img]
Pashgen
Re: water pump with LCD
by kcl1s on Fri Nov 17, 2017 1:00 am
On this line you have lcd.print(sensorValue); but you only assign a value to sensorValue once in setup so it will never change. You do realize your sensor is digital and only gives 0 or 1 value so displaying % is not possible. You can put lcd.print("Wet"); or lcd.print("Dry"); inside your if/else statement if you want words. Don't forget to add the lcd.setCursor(0, 1); in each.
Otherwise I think you have the basic idea. Keep trying.
Keith
kcl1s
by adafruit_support_bill on Fri Nov 17, 2017 6:39 am
Are you sure that you have the sensor connected properly? That looks like an analog sensor, but you are reading like a digital switch, so you will only get values of 0 or 1. Check with the sensor manufacturer for the correct way to connect and read the moisture sensor.
by kcl1s on Fri Nov 17, 2017 7:56 am
Bill,
I thought that too at first then saw the small blue board and Googled for something similar and found this https://www.ebay.com/itm/Soil-Humidity-Moisture-Detection-Digital-Sensor-Module-DC-3-3-5V-E9T7-/122778876038?_trksid=p2385738.m2548.l4275
The description only lists digital out DO but a second look shows an extra pin that the poster is not using. That might be for the raw analog reading.
Pashgen,
What does the documentation for your part say about the 4th unused pin?
Keith
kcl1s
by adafruit_support_bill on Fri Nov 17, 2017 10:02 am
OK. Similar in appearance to the Grove analog moisture sensor - but with just a digital output.
https://www.seeedstudio.com/Grove-Moist ... p-955.html
