Help with Code for Arduino Uno & RTD MAX31865
by petevree on Sat Nov 18, 2017 12:46 pm
First off... thanks so much for a great product and phenomenal instructions.
I have hooked everything up according to your instructions for the MAX31865 RTD Temperature Sensor Amplifier
https://learn.adafruit.com/adafruit-max ... iring-test
I am getting Temperature values that are roughly 1 degree higher than my reference temperature sensor.
Is there any way to provide a more accurate temperature reading by manipulating the code?
Is there a link to a more detailed walk through of the following code:
#define RREF 430.0
  Serial.begin(115200);
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  max.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd = max.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio,8);
  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
  Serial.print("Temperature = "); Serial.println(max.temperature(100, RREF));
Thanks so much!
Pete Vree
petevree
