Bootloader Light for adafruit protrinket not lighting up
- Spotishman
I have the adafruit protrinket 5v, and I plugged it in following all instruction listed on the website, however, it seems that the board does not blink, and the red light does not flash either. I have attempted to hit reset, but nothing seems to occur.
- adafruit_support_carter
Re: Bootloader Light for adafruit protrinket not lighting up
Make sure you are using a good USB cable and that it is not a charge only cable. The bootloader only runs if it sees good USB communications. You may also need to try a different USB port, preferably a USB 2.0 port.
What computer and operating system are you using?
- Spotishman
Windows 10 on a desktop
Did you go through the driver install process?
https://learn.adafruit.com/adafruit-ard ... stallation
- Spotishman
I did indeed, however the lights themselves on the board(only the green, red doesnt come on) are solid
OK, so back to the cable and/or the USB port. Have you tried different USB cables to make sure you don't have a charge only cable?
- Spotishman
unless everycable i own is a charge cable then yes
Hmmm. So you never see anything from the red LED? Not even a little flicker?
Do you ever get that "bahdunk" USB device connected sound from Windows when you plug in the Trinket?
- Spotishman
it says its connected to the computer but i never get a red light, and the green light remains solid
Sounds like the computer is seeing something. Can you post a screen shot of your device manager after you've plugged in the Pro Trinket.
- Spotishman
here is the image ive marked the connected unit
- Attachments
- adafruit.PNG (370.74 KiB) Viewed 509 times
Do you have what's needed to attempt re-programming the bootloader?
https://learn.adafruit.com/introducing- ... bootloader
- Spotishman
So with this i simply need need to connect the uno to the protrinket and upload the code to the uno. I have everything i need to do this and will attempt after work today
Yep, if you have an UNO just follow those directions. Let me know if you run into any snags and what the outcome is.
- Spotishman
got it connected and functioning however im facing a new issue, i cannot seem to reimage it. EDIT 1: ive got the first part down now i have a new issue which is the second image
- Attachments
- Capture 2.PNG (18.83 KiB) Viewed 409 times
- Capture.PNG (12.14 KiB) Viewed 410 times
