I have a Metro M0 successfully running a sketch and interfaces well with the other boards (Wifi and stepper). I am having a problem with two things that are probably related:
1) When I take the reset pin to low, the sketch stops but the system does not reset; and
2) when I unplug the USB and cycle power, the sketch doesn't automatically start
I would like this to run as a standalone item (like the Uno did)...any suggestions?
standalone operation of Metro M0 + Arduino
- Franklin97355
Re: standalone operation of Metro M0 + Arduino
It should run unconnected. Is the code the same on the Uno or are you running a different sketch? Are you using the serial port in your code? Could you post your code so we can try it to see if the problem lies there? Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
- jmtatum
Thanks for the reply! It is a lot of code, and yes it worked on the Uno with no major changes to switch to the Metro. I followed the Adafruit tutorial and set it up fine.
I'll try to run a simple example sketch (like blink) and see if it works disconnected from the USB.
Thinking of it that way, is there anything different I would need to do with Metro to allow Blink to run standalone? I read over the Bootloader methods, but that seemed to be for Python use.
- jmtatum
So, I uploaded the Blink example, and the Metro M0 restarted fine using my hardware reset button (which takes the reset pin low), and also with cycling power. So, you were right, it must be something in the code...
Here is my code. The application is for 2 motors on a wood stove btw...
When I reload this code and try the reset button, everything stops and there are no light indications that anything is happening. The Serial monitor I use for debugging stops as well. Also, cycling power does not work either...
Here are some troubleshooting scenarios, assuming USB is plugged in, and DC power connected (12V):
-unplug USB, everything still works
-cycle power, green light comes on but no autostart
Thanks in advance!
#include <SPI.h>
#include "Adafruit_MAX31855.h" //library for the digital temp controller
#include <Wire.h> //copied from motor example
#include <Adafruit_MotorShield.h> // motor shield library
#include "utility/Adafruit_MS_PWMServoDriver.h" //motor driver
#include <PID_v1.h>
// #include <EEPROM.h> //****REMOVED FOR METRO
#include <Adafruit_RGBLCDShield.h> //LCD display drivers
#include <utility/Adafruit_MCP23017.h>
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
#include <FlashStorage.h>
// Wifi info for Blynk data ******************************************//
char auth[] = “#####BLYNKTOKEN#########”;
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = “*****”;
char pass[] = “#####“;
BlynkTimer timer;
// This function will be called every time Slider Widget
// in Blynk app writes values to the Virtual Pin V4
int SliderTemp;
BLYNK_WRITE(V4)
SliderTemp = param.asInt(); // assigning incoming value from pin V4 to a variable
BLYNK_CONNECTED() {
// Request Blynk server to re-send latest values for all pins
//Blynk.syncAll();
// You can also update individual virtual pins like this:
Blynk.syncVirtual(V4);
//#define BLYNK_PRINT Serial
#define MAXDO 0 // these are for the temp
#define MAXCS 1
#define MAXCLK 2
#define RESETBUTTON 3 // button to store motor positions, then halt
//Define Variables we'll be connecting to for PID controller
double ExSetpoint, ExInput, ExOutput;
double DoorInput, DoorOutput;
double DoorSetpoint=39; //Setpoint for Door is the exhaust position
int DoorMultiple = 5; //number for increment to calculate
//Define stepper positioning. Exhaust fully shut is 0 step, fully open is 50.
int ExhaustPosition = 0;
FlashStorage(ExhaustPosition_storage, int);
int DoorPosition = 50; // Want to start 50 is open
int StepsToMove = 0;
int DoorStepsToMove = 0;
int Counter = DoorMultiple - 1;
int rst = 1; //variable to track reset button; HIGH is not pushed and runs normally
int runprogram = 1; //variable to track reset state
//Specify the links and initial tuning parameters
double ExKp=1, ExKi=2, ExKd=.01;
double DKp=.5, DKi=1, DKd=.01;
PID ExPID(&ExInput, &ExOutput, &ExSetpoint, ExKp, ExKi, ExKd, P_ON_M, DIRECT);
PID DoorPID(&DoorInput, &DoorOutput, &DoorSetpoint, DKp, DKi, DKd, P_ON_M, REVERSE);
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// setup variables for averaging thermocouple readings
const int numReadings = 10; // number of readings to average
double readings[numReadings]; // the readings from the thermocouple
int readIndex = 0; // the index of the current reading
double total = 0; // the running total
double average = 0; // the average
// setup time variable for averaging temp
unsigned long intervalAvg=100; // the time we need to wait
unsigned long previousMillisAvg=0; // millis() returns an unsigned long.
unsigned long intervalPID=3000; // interval to calculate PID
unsigned long previousMillisPID=0; //used to store the previous time for comparison
// initialize the motor
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor1 = AFMS.getStepper(200, 1);
Adafruit_StepperMotor *myMotor2 = AFMS.getStepper(200, 1);
//initialize the display
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
#define OFF 0x0
#define ON 0x1
// LCD display is 16x2
// Main menu array
String mainMenu[10];
// Main menu default choice
int mainSwitch = 0;
int mainSwitchOld = 0;
// Amount of items in our main menu.
// Can be found by formula:
// (Amount_of_items - 1)
#define mainMenuItems 8
uint8_t buttons = 0; // variable to read the buttons
int InMainMenu = 0; // variable set to 1 when in Main Menu
int CursorPosit = 1; // position of cursur in the menus
void myTimerEvent()
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V0, (int)ExInput); // send out the temperature input
Blynk.virtualWrite(V1, (int)ExSetpoint); // send out the temperature setpoint
Blynk.virtualWrite(V2, ExhaustPosition); // send out the exhaust position
Blynk.virtualWrite(V3, DoorPosition); // send out the door position
while (!Serial); // wait for Serial on Leonardo/Zero, etc
Serial.begin(9600);
Blynk.begin(auth, ssid, pass);
//setup a function to be called to send data to Blynk
timer.setInterval(5000L, myTimerEvent);
// Setup LCD
lcd.begin(16, 2);
lcd.setBacklight(ON);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Startup ");
lcd.setCursor(0,0);
// Filling our main menu items
mainMenu[0] = "Setpoint "; //temp setpoint
mainMenu[1] = "Set Exhaust shut"; //exhaust damper Position
mainMenu[2] = "Set Door shut "; //door damper position
mainMenu[3] = "Exhaust Kp ";
mainMenu[4] = "Exhaust Ki ";
mainMenu[5] = "Exhaust Kd ";
mainMenu[6] = "Door Kp ";
mainMenu[7] = "Door Ki ";
mainMenu[8] = "Door Kd ";
// wait for MAX chip to stabilize
delay(500);
AFMS.begin(); // motor shield
myMotor1->setSpeed(5); // 5 rpm
myMotor2->setSpeed(5);
ExhaustPosition = ExhaustPosition_storage.read(); //set exhaust position to stored value
DoorPosition = 50;
DoorStepsToMove = 50 - DoorPosition;
myMotor1->step(ExhaustPosition, BACKWARD, SINGLE); //return to start position zero
myMotor2->step(DoorStepsToMove, BACKWARD, SINGLE);
DoorPosition = 50;
delay(3000);
//initialize the variables we're linked to
ExInput = thermocouple.readFarenheit();
DoorInput = ExhaustPosition;
//ExSetpoint = 85.0;
//turn the PID on
ExPID.SetMode(AUTOMATIC);
ExPID.SetOutputLimits(0, 50);
DoorPID.SetMode(AUTOMATIC);
DoorPID.SetOutputLimits(0, 50);
//setup reset button
pinMode(RESETBUTTON, INPUT); // used to set GPIO to store setpoint and exhaust position
//clear out average temps
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
//set PID previous time to now
previousMillisPID = millis();
lcd.clear();
// send data to blynk;
Blynk.run();
timer.run(); //initiates Blynktimer
unsigned long currentMillis = millis(); // grab current time
rst = digitalRead(RESETBUTTON); //Check the reset button. If pressed, it goes low.
buttons = lcd.readButtons(); //Check buttons
ExSetpoint = SliderTemp; // setpoint for temp to match with slider in Blynk
//MENU & SETUP SECTION
if (buttons & BUTTON_SELECT) { // go into the Main Menu when Select is pressed
InMainMenu=HIGH;
while(lcd.readButtons()) { } // waits for buttons to release
MainMenuDisplay(); // diplays the first menu item
while(InMainMenu) { // while we are in the Main Menu...
// this section gets called repeatedly when no buttons are pressed. We are
// checking for buttons to be pushed, and then will scroll or take action.
buttons = lcd.readButtons(); // fills buttons with state of LCD buttons
MainMenuBtn(); // checks to see if up or down was selected, and scrolls
if(buttons & BUTTON_SELECT) //enter selected menu if select button is pressed
switch (mainSwitch)
case 0:
Setpoint();
MainMenuDisplay();
break;
case 1:
SetEx();
MainMenuDisplay();
break;
case 2:
SetDoor();
MainMenuDisplay();
break;
case 3:
ExhaustKp();
MainMenuDisplay();
break;
case 4:
ExhaustKi(); //Exhaust Ki
MainMenuDisplay();
break;
case 5:
ExhaustKd(); //Exhaust Kd
MainMenuDisplay();
break;
case 6:
DoorKp(); //Door Kp
MainMenuDisplay();
break;
case 7:
DoorKi(); //Door Ki
MainMenuDisplay();
break;
case 8:
DoorKd(); //Door Kd
MainMenuDisplay();
break;
while(lcd.readButtons()) { } // waits for buttons to release after exit from submenu
} // after this IF statement, back in the MainMenu. check for left to exit Main Menue
if(lcd.readButtons()==BUTTON_LEFT) { //Check left button to leave Main Menu
Serial.print("Trying to leave");
mainSwitch=0;
mainSwitchOld=0;
InMainMenu=0;
} // end of the Main Menu WHILE statement, check to see if we can exit
lcd.clear(); //clear screen, allow operating menu to write to LCD
// MEASURE & AVERAGE TEMP SECTION
// this section reads temp and calculates a running average of temp, after a certain interval
if ((unsigned long)(currentMillis - previousMillisAvg) >= intervalAvg) {
// subtract the oldest reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = thermocouple.readFarenheit();
while (isnan(readings[readIndex])) {
delay (5);
lcd.setCursor(8,1);
lcd.print("n");
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
ExInput = average;
lcd.setCursor(0,0);
lcd.print("SP=");
lcd.setCursor(3,0);
lcd.print(ExSetpoint);
lcd.setCursor(0,1);
lcd.print(" T=");
lcd.setCursor(3,1);
lcd.print(ExInput);
lcd.setCursor(8,1);
lcd.print(" ");
previousMillisAvg = millis();
// CALCULATE PID / MOVE exhaust SECTION (if reset hasn't been pushed)
// this section calculates the PID after a certain amount of time (interval PID)
if ((unsigned long)(currentMillis - previousMillisPID) >= intervalPID) {
ExPID.Compute();
Counter++; // count the number of times we calculate exhaust PID to trigger door PID
Serial.print(Counter);
Serial.print(" ");
Serial.print(DoorMultiple);
Serial.print(" ");
if (Counter == DoorMultiple) {
DoorPID.Compute();
Counter = 0;
DoorStepsToMove = DoorOutput-DoorPosition;
if (rst == HIGH and runprogram == HIGH) {
StepsToMove = ExOutput - ExhaustPosition;
//Serial.print(StepsToMove);
//Serial.print(" ");
if (StepsToMove > 0) {
myMotor1->step(StepsToMove, FORWARD, SINGLE); }
else {
if (StepsToMove < 0) {
myMotor1->step(-StepsToMove, BACKWARD, SINGLE);
ExhaustPosition = ExhaustPosition + StepsToMove;
//move DoorMotor
if (DoorStepsToMove > 0) {
myMotor2->step(DoorStepsToMove, FORWARD, SINGLE);
DoorPosition = DoorPosition + DoorStepsToMove;
else {
if (DoorStepsToMove < 0) {
myMotor2->step(-DoorStepsToMove, BACKWARD, SINGLE);
// Print Exhaust Position to LCD
Serial.print(ExhaustPosition);
Serial.print(" ");
lcd.setCursor(11,0);
lcd.print("EP=");
lcd.setCursor(14,0);
if (ExhaustPosition < 10) {
lcd.print(ExhaustPosition);
lcd.print(" "); }
else {
lcd.print(ExhaustPosition); }
// Print Door Position to LCD
Serial.print(DoorPosition);
Serial.print(" ");
lcd.setCursor(11,1);
lcd.print("DP=");
lcd.setCursor(14,1);
if (DoorPosition < 10) {
lcd.print(DoorPosition);
lcd.print(" "); }
else {
lcd.print(DoorPosition); }
Serial.println(" ");
//STORE VARIABLES FOR NEXT TIME
// if reset button is pushed, store exhaust position and setpoint and then halt motor movement
if (rst == LOW and runprogram == HIGH) {
ExhaustPosition_storage.write(ExhaustPosition);
// removed for METRO*** EEPROM.write(1, ExSetpoint);
runprogram = LOW;
lcd.clear();
lcd.print("Exiting");
delay(5);
void Setpoint()
if(ExSetpoint>=100) CursorPosit = 2;
else CursorPosit = 1;
lcd.setCursor(CursorPosit,1);
lcd.blink();
while(lcd.readButtons()) {} // waits for buttons to release
while(lcd.readButtons()!=BUTTON_LEFT)
if(lcd.readButtons() == BUTTON_UP) {
ExSetpoint++;
delay(250);
lcd.setCursor(0,1);
lcd.print((int)ExSetpoint);
lcd.print(" ");
else if(lcd.readButtons() == BUTTON_DOWN) {
ExSetpoint--;
delay(250);
lcd.setCursor(0,1);
lcd.print(" ");
//adjust for up and down, save as new Setpoint
lcd.noBlink();
Blynk.virtualWrite(V4, ExSetpoint);
SliderTemp=ExSetpoint;
void SetEx()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("DP:move to close");
lcd.setCursor(0,1);
lcd.print("Enter to set");
while(lcd.readButtons()!= BUTTON_LEFT)
//Insert Task for moving DP motor
void SetDoor()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("No motor for now");
Serial.print("Waiting..");
//Insert Task for Menu C here
void ExhaustKp()
if(ExKp>=10) CursorPosit = 3;
else CursorPosit = 2;
lcd.blink();
ExKp = ExKp + .1;
delay(250);
lcd.setCursor(0,1);
lcd.print(ExKp);
lcd.print(" ");
ExKp = ExKp - .1;;
delay(250);
lcd.setCursor(0,1);
lcd.print(ExKp);
lcd.print(" ");
lcd.noBlink(); //stop blinking when exit to main menu
void ExhaustKi()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Exhaust Ki ");
//Insert Task for Menu D here
void ExhaustKd()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Exhaust Kd ");
void DoorKp()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Door Kp ");
void DoorKi()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Door Ki ");
void DoorKd()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Door Kd ");
void MainMenuDisplay()
lcd.clear();
lcd.setCursor(0,0);
lcd.print(mainMenu[mainSwitch]);
lcd.setCursor(0,1);
switch (mainSwitch)
case 0: // Setpoint
break;
case 1: // Set Exhaust exhaust position
lcd.print("Position=");
break;
case 2:
// Set Inlet damper position
lcd.print("n/a"); // not connected yet
break;
case 3:
lcd.print(ExKp); //Exhaust Kp
break;
case 4:
lcd.print(ExKi); //Exhaust Ki
break;
case 5:
lcd.print(ExKd); //Exhaust Kd
break;
case 6:
lcd.print(DKp); //Door Kp
break;
case 7:
lcd.print(DKi); //Door Ki
break;
case 8:
lcd.print(DKd); //Door Kd
break;
void MainMenuBtn() //This program scrolls the menu up and down only
//Serial.print("In MainMenuBtn");
//Serial.println(" ");
//buttons = lcd.readButtons();
if(buttons & BUTTON_DOWN)
Serial.print("BUTTON DOWN");
mainSwitch++;
if(mainSwitch > mainMenuItems)
mainSwitch = 0;
else if(buttons & BUTTON_UP)
mainSwitch--;
if(mainSwitch < 0)
mainSwitch = mainMenuItems;
if(mainSwitch != mainSwitchOld) //only update display when page change
MainMenuDisplay();
mainSwitchOld = mainSwitch;
Thanks in advance!
- Franklin97355
- jmtatum
That's it, many thanks! This was leftover from some examples I used, and never caused a problem with the Uno. Not sure why it would cause a halt with the Metro, but that did it!
Thanks for taking the time.
