I'm up to this part:
https://learn.adafruit.com/adafruit-fea ... idkeyboard
and its telling me"If using software or hardware Serial UART:
This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode!
Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done)"
I don't have a "mode pin" or a "cts pin" so I can't do any of that. why don't I have those pins? is my feather defective or incomplete?
Adafruit_BluefruitLE example missing pins?
- Franklin97355
Re: Adafruit_BluefruitLE example missing pins?
That tutorial is for multiple boards and, if your board does not have a mode pin you can ignore that.
