#define TCAADDR 0x70
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
Arduino: 1.8.5 (Windows 8.1), Board: "Arduino/Genuino 101"
See (1) in post below.
Compiling sketch...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp.o"
C:\Users\user\Documents\Arduino\PortSelectTCA\PortSelectTCA.ino: In function 'void tcaselect(uint8_t)':
PortSelectTCA:6: error: 'Wire' was not declared in this scope
exit status 1
#include<Wire.h>
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\user\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\user\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10805 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_367693 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_66396 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\openocd\0.9.0+0.1 -prefs=runtime.tools.arduino101load.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28 -prefs=runtime.tools.arc-elf32.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1 -prefs=runtime.tools.flashpack.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\flashpack\1.0.0 -verbose C:\Users\user\Documents\Arduino\PortSelectTCA\PortSelectTCA.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\user\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\user\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10805 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_367693 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_66396 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\openocd\0.9.0+0.1 -prefs=runtime.tools.arduino101load.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28 -prefs=runtime.tools.arc-elf32.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1 -prefs=runtime.tools.flashpack.path=C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\flashpack\1.0.0 -verbose C:\Users\user\Documents\Arduino\PortSelectTCA\PortSelectTCA.ino
Using board 'arduino_101' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7
Using core 'arduino' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7
Detecting libraries used...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp" -o "nul"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp" -o "nul"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src\Wire.cpp" -o "nul"
Generating function prototypes...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\user\AppData\Local\Temp\arduino_build_367693\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire\src\Wire.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\libraries\Wire\Wire.cpp.o"
Compiling core...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101\variant.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\variant.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WInterrupts.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WInterrupts.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\hooks.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\hooks.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\i2c.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\i2c.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\soc_i2c.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\soc_i2c.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_analog.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_analog.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_digital.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_digital.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_shift.c" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_shift.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\CDCSerialClass.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\CDCSerialClass.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\IPAddress.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\IPAddress.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Print.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Print.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\RingBuffer.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\RingBuffer.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Stream.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Stream.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Tone.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Tone.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\UARTClass.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\UARTClass.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WMath.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WMath.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WString.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WString.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\abi.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\abi.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\main.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\main.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\new.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\new.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\stdlib_noniso.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\stdlib_noniso.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10805 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_pulse.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_pulse.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WInterrupts.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\hooks.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\i2c.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\soc_i2c.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_analog.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_digital.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_shift.c.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\CDCSerialClass.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\IPAddress.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Print.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\RingBuffer.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Stream.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\Tone.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\UARTClass.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WMath.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\WString.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\abi.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\main.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\new.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\stdlib_noniso.cpp.o"
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\core.a" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\wiring_pulse.cpp.o"
Archiving built core (caching) in: C:\Users\user\AppData\Local\Temp\arduino_cache_66396\core\core_Intel_arc32_arduino_101_c22fa68c2f14df2f90b6717d2161784f.a
Linking everything together...
"C:\Users\user\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -nostartfiles -nodefaultlibs -nostdlib -static -Wl,-X -Wl,-N -Wl,-mcpu=quarkse_em -Wl,-marcelf -Wl,--gc-sections "-TC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101/linker_scripts/flash.ld" "-Wl,-Map,C:\Users\user\AppData\Local\Temp\arduino_build_367693/PortSelectTCA.ino.map" -o "C:\Users\user\AppData\Local\Temp\arduino_build_367693/PortSelectTCA.ino.elf" "-LC:\Users\user\AppData\Local\Temp\arduino_build_367693" "-LC:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" -Wl,--whole-archive "-larc32drv_arduino101" -Wl,--no-whole-archive -Wl,--start-group "-larc32drv_arduino101" -lnsim -lc -lm -lgcc "C:\Users\user\AppData\Local\Temp\arduino_build_367693\sketch\PortSelectTCA.ino.cpp.o" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\libraries\Wire\Wire.cpp.o" "C:\Users\user\AppData\Local\Temp\arduino_build_367693\core\variant.cpp.o" "C:\Users\user\AppData\Local\Temp\arduino_build_367693/core\core.a"
C:\Users\user\AppData\Local\Temp\arduino_build_367693/core\core.a(main.cpp.o): In function `main':
C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino/main.cpp:43: undefined reference to `setup'
C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino/main.cpp:47: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Using library Wire at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\Wire
exit status 1
Error compiling for board Arduino/Genuino 101.
