Yesterday I plugged my Mini Trinket into my computer via USB. I had attached 1 loose NeoPixel to it and was trying to run the FlashLED library. After a few seconds the trinket was not responding to the Arduino IDE and a small bit a smoke came out of it. After further inspection, a piece on the trinket board seemed to have burnt out.I am not sure what happened or if this was a defect. I followed instructions on the Learn section of your page. Can I get a replacement and some advice here; not really sure what went wrong.
I connected the LED according to the goggle tutorial. Below are the details of my purchase on February 9th with the items in question. The order number is there as well. I Have also attached pictures. The only items used where the Trinket and 1 NeoPixel
Thank you
Order Confirmation No: 1675695-8914766923
1 x NeoPixel 5050 RGB LED with Integrated Driver Chip - 10 Pack[ID:1655] =
$4.50
1 x Adafruit Trinket - Mini Microcontroller - 5V Logic[ID:1501] = $6.95
1 x Lithium Ion Polymer Battery - 3.7v 1200mAh[ID:258] = $9.95
1 x Adafruit Micro Lipo - USB LiIon/LiPoly charger (v1) [ID:1304] = $5.95
Trinket Burnout -Neo Pixel Project
- dehernandez86
- Full.jpg (425.02 KiB) Viewed 620 times
- Franklin97355
Re: Trinket Burnout -Neo Pixel Project
Without a battery connected the BAT pin has no power. Not sure what you may have done to the Trinket as nothing should smoke if things are correctly connected.
- dehernandez86
Even with a USB cable connected to the trinket from PC? I had nothing else connected but one pixel and a usb cable. Nothing else was soldered other than those three points:-(. Waiting on engineers feed back from adafruit
- dehernandez86
Franklin, below see the image of the diagram I followed. https://learn.adafruit.com/kaleidoscope ... -soldering
as for the burn out. Everything was wired connected. The smoke came as soon as the IDE was uploading the script then the smoke happened
Here is the code I ran from:
https://learn.adafruit.com/kaleidoscope ... duino-code
- led_pixels_goggles-diagram.jpg (107.15 KiB) Viewed 540 times
- Franklin97355
Where did you connect the LiPo battery?
- dehernandez86
With The old board, shown above, I was not able to even get to the LiPo because it popped smoke as I stated a month ago. I moved on to a pro trinket, same thing happened, I even had it connected to a bread board to avoid the same occurrence. But it still popped smoke.
I have now moved on to a third board, back to a trinket. And this time I tried the “Blink Test” and I even purchased a 12 neopixel ring to attempt the goggle set up you guys have. I figured let me try one of their projects; maybe it’s me. And yet again nothing. No response from the board. The new board is from Order Confirmation No: 1702369-9584856408
New boards came in and now this is the error I am getting. SO frustrating.
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
The reason I posted a new thread is because, as you can see. The feedback I received ended with “not sure what you may have done to the board”. I figured maybe he’s right and I just messed up the board. On my third one now, first two popped smoke doing tutorials from this site.
Third one hasn’t popped smoke, yet, but still no response.
So I am down 2 boards from before and now I have 2 new ones.
With the new boards I have purchased and attached JST connectors. But there’s no point in moving on to connecting the LiPo because the board is not responding to the IDE
- dehernandez86
Here is the Verbose
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Adafruit Trinket (ATtiny85 @ 16MHz)"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Daniel Hernandez\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Daniel Hernandez\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Daniel Hernandez\Documents\Arduino\libraries -fqbn=adafruit:avr:trinket5 -ide-version=10805 -build-path C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229 -warnings=none -build-cache C:\Users\DANIEL~1\AppData\Local\Temp\arduino_cache_301155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Daniel Hernandez\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Daniel Hernandez\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Daniel Hernandez\Documents\Arduino\libraries -fqbn=adafruit:avr:trinket5 -ide-version=10805 -build-path C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229 -warnings=none -build-cache C:\Users\DANIEL~1\AppData\Local\Temp\arduino_cache_301155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
Using board 'trinket5' from platform in folder: C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\adafruit\hardware\avr\1.4.12
Using core 'arduino' from platform in folder: C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21
Detecting libraries used...
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_TRINKET5 -DARDUINO_ARCH_AVR "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\adafruit\hardware\avr\1.4.12\variants\tiny8" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_TRINKET5 -DARDUINO_ARCH_AVR "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\adafruit\hardware\avr\1.4.12\variants\tiny8" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\sketch\Blink.ino.cpp" -o "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_TRINKET5 -DARDUINO_ARCH_AVR "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\adafruit\hardware\avr\1.4.12\variants\tiny8" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\sketch\Blink.ino.cpp" -o "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=attiny85 -o "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.elf" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229\sketch\Blink.ino.cpp.o" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/..\arduino_cache_301155\core\core_adafruit_avr_trinket5_918d6709cb27276a21eb8d11d20a0607.a" "-LC:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229" -lm
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.elf" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.eep"
"C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.elf" "C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.hex"
Sketch uses 672 bytes (12%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -pattiny85 -cusbtiny -Uflash:w:C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_132229/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Daniel Hernandez\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
Compiling sketch...
Compiling core...
Using Port : usb
- dehernandez86
Now I am getting this error after reinstalling drivers
avrdude: error: usbtiny_transmit:
