Hello, I teach Middle school Technology and Engineering here at the American International School of Lagos. My 8th graders are designing and building the classic marble sorting machine taking in to account marble size, color, size, and magnetism. For color we are using the TCS3425 Color sensor. Eventually we want that to use that sensor to input a 28JYJ-48 stepper motor to sort the marbles. Before we get to that though, I just want the students to change the color of an RGB LED with the sensor and Arduino. I'm using this webpage as guide https://learn.adafruit.com/adafruit-col ... s/overview. The circuit is straight forward and easy. Where I am struggling is the code. This is my first year teaching on the Arduino platform.
I have taken the code from the TCS3425 sensor Ardunio library. I have try to upload the code to my board but always receive an error message. I have looked at all the code in library and am struggling to make this sense of this. Can anyone provide a link or paste the code I need in a response.
Thanks for your time, as living here in Nigeria I'm a bit isolated from a coding and DIY community.
Andrew Bauman
TCS3425 color sensor library code upload issues
- Abaumanster
Re: TCS3425 color sensor library code upload issues
It would be helpful if you posted the text of the error message.I have try to upload the code to my board but always receive an error message.
- Abaumanster
Thanks for responding so quickly to me and my arduino problem.
Well after an evening of research and work I realized I was not using the Library correctly. I was copying and pasting the entire .cpp code and not working within the examples.
Working with the right code (which uploaded) I have come to a few more observations with using the color sensor. 3 things:
-One it looks like the pins that come with the the sensor must be soldered for a good connection (exactly as you state in your tutorial). Right now I just have the pins that came with the sensor pushed through the holes and into the bread board. Now the search for fine soldering iron tip begins. I can make the sensor work when I gently press the wires toward the sensor pushing the sensors contact holes against the pins
- I noticed in the code has #include <wire.h> is that a standard or universal library that is pre-loaded? I understand that it is used for SDA and SCL components
-Lastly when I run the code for the colorview sketch. My LED is always blue but the numbers in my cereal monitor change as I introduce different colored items over the sensor. I have played around with different resistors to limit the current to the blue RGB LED PIN.
Would love any feed back and thoughts on my three observations and thank you for your time
If you are new to soldering, we have a helpful tutorial here: https://learn.adafruit.com/adafruit-gui ... -soldering-One it looks like the pins that come with the the sensor must be soldered for a good connection (exactly as you state in your tutorial). Right now I just have the pins that came with the sensor pushed through the holes and into the bread board. Now the search for fine soldering iron tip begins. I can make the sensor work when I gently press the wires toward the sensor pushing the sensors contact holes against the pins
The wire library is installed as part of the standard Arduino IDE package.- I noticed in the code has #include <wire.h> is that a standard or universal library that is pre-loaded? I understand that it is used for SDA and SCL components
If you post photos of your circuit, we can try to spot the problem.-Lastly when I run the code for the colorview sketch. My LED is always blue but the numbers in my cereal monitor change as I introduce different colored items over the sensor. I have played around with different resistors to limit the current to the blue RGB LED PIN.
- Abaumanster
Thanks again for your quick responses.
Below are photos.
RGB: Red is pin 3, Green is pen 5, and Blue is pin 6. Ground is to Ground
The Sensor: is 5 volts to VIN, Ground to Ground and SDA to A4 and SCL to A5.
Code I'm running is color view and I can get a reading that changes with color on my Serial Monitor
The RGB LED works when I run a color changing code. The resistors are 330ohms though I did try different values as a silly guess.
Just can't get my RGB to turn colors when the Serial Monitor value changes.
My students and I would love some help with this puzzle.
Thank you again for your time and great support
Below are photos.
- monitor.jpg (44.03 KiB) Viewed 662 times
- adafruit circuit.jpg (102.28 KiB) Viewed 662 times
- adafruit.jpg (49.08 KiB) Viewed 662 times
From what I can see, the wiring looks correct. But you will need to solder those headers for reliable operation.
https://learn.adafruit.com/adafruit-col ... rsion-only
Please post your color changing code that works.The RGB LED works when I run a color changing code.
- Abaumanster
Here the code I use to cycle the RGB through a range of colors.
https://learn.adafruit.com/adafruit-ard ... ino-sketch
I will be soldering the contacts soon once I receive a fine tipped iron. Though if the Serial monitor is showing data and its changing with different colors, wouldn't that suggest the sensor is working?
Is there another set of code I need to combine with library code colorview to make the sensor "talk" to the RGB LED ?
Thanks for your time and insight
That code assumes that your led is wired to pins 9, 10 and 11. If you change it to use the same pins as the color view sketch - i.e. the ones that are connected in your photo, does it still work?
