Cannot upload to Feather 32u4
by ianmackinnon on Tue Mar 20, 2018 7:50 am
I have just received a Feather 32u4 but I have been unable to upload anything to it.
I have Arduino IDE 1.8.5 running on Linux. I have installed and updated the Adafruit board URL. I have Adafruit Feather 32u4 selected as the board type. The board appears on /dev/ttyACM0 and board info reports:
BN: Adafruit Feather 32u4
VID: 239A
PID: 800C
SN: (null)
I have tried the following:
Plug the board in and upload. Results in the error:
avrdude: Device signature = 0x3f0d0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Wrong microcontroller found.  Did you select the right board from the Tools > Board menu?
Press reset and upload. Results in the error:
avrdude: butterfly_recv(): programmer is not responding
Upload and press reset. Results in the error:
#avrdude: error: programmer did not respond to command: set addr
Double press reset and upload. Results in the error:
Port name - /dev/ttyACM0; Method name - openPort(); Exception type - Port busy.
Can you please tell me what I have to do to upload a program to this board?
Many thanks.
ianmackinnon
Re: Cannot upload to Feather 32u4
by adafruit_support_carter on Tue Mar 20, 2018 11:51 am
Did you add the udev rules?
https://learn.adafruit.com/adafruit-ard ... udev-rules
In addition to adding the URL, did you also install the board support packages?
https://learn.adafruit.com/adafruit-fea ... -ide-setup
by ianmackinnon on Tue Mar 20, 2018 2:50 pm
I have installed the udev rules and now uploading is working perfectly.
Thanks for the quick response.
ianmackinnon
by adafruit_support_carter on Tue Mar 20, 2018 4:20 pm
Excellent. Glad that worked.
