VC0607 "No camera found?"
Re: VC0607 "No camera found?"
by estillcn on Mon Apr 16, 2018 4:41 pm
Very sorry, I posted the wrong code, I have just fixed it, and I believe I have changed the baud rate. I can double check. This is the snapshot example code.
estillcn
by adafruit_support_bill on Mon Apr 16, 2018 4:57 pm
The best way to test the camera is via the Comm Tool:
https://learn.adafruit.com/ttl-serial-c ... g-commtool
by estillcn on Mon Apr 16, 2018 5:07 pm
The commtool has not worked, it always gives me the cmd timeout response
estillcn
by adafruit_support_bill on Mon Apr 16, 2018 5:25 pm
Have you changed the wiring? The Comm Tool needs the camera wired to pins 0 and 1.
by estillcn on Mon Apr 16, 2018 5:40 pm
I have not tried that, does it work with the arduino?
estillcn
by adafruit_support_bill on Mon Apr 16, 2018 6:21 pm
Yes. Follow the instructions in the guide: https://learn.adafruit.com/ttl-serial-c ... g-commtool
by estillcn on Wed Apr 18, 2018 5:18 pm
Hello again, I have finally gotten around to testing the camera with commtool and I got the same response that I have been getting even with the updated resistors in the wiring and putting the tx and rx into the pins 0 and 1. I will go through the steps and when I try and click get version, it says "cmd timeout". Any other suggestions?
estillcn
by adafruit_support_bill on Wed Apr 18, 2018 6:26 pm
Try adjusting the baud-rate in the Comm Tool.
by estillcn on Wed Apr 18, 2018 6:52 pm
Yes I have already done that for every baud rate available with no success.
estillcn
by adafruit_support_bill on Wed Apr 18, 2018 7:22 pm
Double-check that you have Tx going to pin 1 and Rx to pin 0.
by estillcn on Wed Apr 18, 2018 7:26 pm
The way you are saying it, you want me to put the rx on the camera to the rx on the arduino? And tx the same as well?
estillcn
by adafruit_support_bill on Wed Apr 18, 2018 7:43 pm
That is correct - because you are using those pins to communicate with your PC via the USB/Serial chip - not with the Arduino processor. Your Arduino should be loaded with the 'empty sketch' as shown in the guide: https://learn.adafruit.com/ttl-serial-c ... g-commtool
by estillcn on Wed Apr 18, 2018 7:47 pm
Ok, I managed to try it the way that you said, I am unsure if I have the divider right, if you want to double check my picture from before. I still get the "cmd timeout" I checked using all of the different baud rates as well.
estillcn
by adafruit_support_bill on Wed Apr 18, 2018 7:51 pm
Yes, the divider looks correct. But I can't see which camera pin it is connected to. Make sure that it is on the Rx pin.
by estillcn on Wed Apr 18, 2018 7:56 pm
It is on the rx pin.
estillcn
