65 years old and still trying
by wpa6702 on Thu Apr 12, 2018 4:07 pm
Can someone please help me. I always wanted to do electronics and now that I am 65 years old
and have cancer I'm gonna try.
I bought the 2 products below from 2 sites and what I need to know is
how do I hook up the adafruit Amp to the MP3 Player Board. The reason I am doing this is I want the Mp3 Player board to be
Louder when I hook the speaker to it. Can anyone help? Thank You in advance
USB Flash Drive Micro SD TF Card MP3 Player Board Module w/ Switches & 2W Amplifier $2.49
https://envistiamall.com/collections/au ... -amplifier
Adafruit Mono 2.5W Class D Audio Amplifier - PAM8302
PRODUCT ID: 2130
https://www.adafruit.com/product/2130
wpa6702
Re: 65 years old and still trying
by adafruit_support_bill on Thu Apr 12, 2018 4:31 pm
Connecting the amplifier board to your MP3 layer should not be too difficult. But the difference between 2W and 2.5W is probably not going to make a big difference in volume.
What speaker are you planning to drive with this?
To connect the output of the MP3 to the amp you would need a 3.5mm plug like this: https://www.adafruit.com/product/1800
And some wire.
You would connect the 'tip' of the plug to A+ and the 'shield' of the plug to A-.
Connect VIN to the positive terminal of your power supply (2v to 5.5v) and the GND to the negative terminal.
by wpa6702 on Thu Apr 12, 2018 4:48 pm
The people here are amazing I'm gonna try it . I thank You anyone else have any ideas..
wpa6702
by wpa6702 on Thu Apr 12, 2018 5:00 pm
here is the amp
wpa6702
by wpa6702 on Sun Apr 15, 2018 7:20 am
Do I need 2 separate power supplies????????? Can anyone help?
wpa6702
by adafruit_support_bill on Sun Apr 15, 2018 8:49 am
You can run them both from the same power supply.
You have not answered the question asked earlier. What speaker are you trying to drive with this?
by wpa6702 on Sun Apr 15, 2018 9:56 am
wpa6702
by wpa6702 on Sun Apr 15, 2018 10:10 am
I uploaded a picture of exactly what I want to do.. Can you please show me where the wires get put on to join the boards together, which board do I use to connect the speakers to, since both boards have speaker connections
wpa6702
by adafruit_support_bill on Sun Apr 15, 2018 10:24 am
You will get more sound out of the 3" 4-ohm speaker than from the smaller 8-ohm speaker.
To connect the two boards, you will need to make a cable that plugs into the jack on your MP3 board, and connect it as described above.
And some wire.
by wpa6702 on Sun Apr 15, 2018 10:34 am
I think I got it now and I thank You. I can connect the power supply to either board am I correct?
wpa6702
by adafruit_support_bill on Sun Apr 15, 2018 8:14 pm
You will need to connect power to both of the boards.
by wpa6702 on Sun Apr 15, 2018 8:54 pm
Thank You
wpa6702
