This is my trial by fire sorta speak, so my first project is to control 4 servos which i have hooked up to the shield and to control them with ada 4-button remote with the momentary receiver. The servos will basically fully open with one button and close with another, I have tested the board with the pmw servo library and everything is all good same with the Rf receiver/remote. I just don't understand how to correctly put everything together and work properly.
~Thanks for reading!!!
servo shield/Rf reciever/Rf remote coding help
- sassmaster
- Franklin97355
Re: servo shield/Rf reciever/Rf remote coding help
Post your code as you have it and explain what is not working. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
- sassmaster
This is an example for our Adafruit 16-channel PWM & Servo driver
Servo test - this will drive 8 servos, one after the other on the
first 8 pins of the PCA9685
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/products/815
These drivers use I2C to communicate, 2 pins are required to
interface.
products from Adafruit!
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(&Wire, 0x40);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN 150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // this is the 'maximum' pulse length count (out of 4096)
// our servo # counter
uint8_t servonum = 0;
int pos = 0; // variable to store the servo position
Serial.begin(9600);
Serial.println("8 channel Servo test!");
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
delay(10);
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000000; // convert to us
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
// Sweep the servos
for (uint16_t pulselen = 0; pulselen < SERVOMAX-SERVOMIN; pulselen++) {
for (int servonum = 0; servonum<8; servonum++)
pwm.setPWM(servonum, 0, SERVOMIN+pulselen);
for (int servonum = 8; servonum<16; servonum++)
pwm.setPWM(servonum, 0, SERVOMAX-pulselen);
delay(150);
I got the servos working together but need them to move at the same speed as they are going at the end of the loop. For the remote i only used the digtal button example that came with to test it, i dont have code for it to work for the servosfranklin97355 wrote:Post your code as you have it and explain what is not working. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
- sassmaster
So i managed to work out one servo being controlled with the rf remote/receiver without the shield being attached. Now i'm getting a problem of a long delay after i press the button, sometimes it is very quick and other time it is long. Here is the code im using
#include <Servo.h>
int A = 8; // button A input
int B = 7; // button D input
int servoPin = 9;
int angle = 1;
int change = 85; // this value determines how much the angle changes each time through the loop
Servo myservo;
void setup(){
pinMode(A, INPUT); // initialize pins
pinMode(B, INPUT);
digitalWrite(A, LOW); // set internal pull up resistors
digitalWrite(B, LOW);
myservo.attach(servoPin);
void loop(){
if( digitalRead(A) == HIGH) {
// here if increment switch pressed
angle = angle + change;
if( digitalRead(B) == HIGH) {
// here if decrement switch pressed
angle = angle - change;
angle = constrain(angle, 5, 170); // limit value of angle
myservo.write(angle);
delay(20);
