avrdude: error reading system
by jeremyzschau on Sat Aug 11, 2018 11:36 pm
I am trying to upload to my gemma. Please help.
Arduino: 1.8.5 (Mac OS X), Board: "Adafruit Gemma (ATtiny85 @ 8MHz)"
Sketch uses 3844 bytes (72%) of program storage space. Maximum is 5310 bytes.
Global variables use 187 bytes of dynamic memory.
avrdude: can't open config file "/Users/jeremy/Library/Arduino15/packages/adafruit/hardware/avr/1.4.13/bootloaders/gemma/avrdude.conf": No such file or directory
avrdude: error reading system wide configuration file "/Users/jeremy/Library/Arduino15/packages/adafruit/hardware/avr/1.4.13/bootloaders/gemma/avrdude.conf"
jeremyzschau
Re: avrdude: error reading system
by adafruit2 on Sun Aug 19, 2018 12:24 pm
thats.. weird, try uninstalling-reinstalling arduino and the adafruit board support?
adafruit2
Site Admin
by jeremyzschau on Thu Oct 04, 2018 6:33 pm
Is there a link about how to uninstall? I think I will replace the gemma with M0 hoping the new software will fix the problem.
jeremyzschau
by adafruit2 on Thu Oct 04, 2018 11:10 pm
go to the Board Manager and uninsall the adafruit avr package
adafruit2
Site Admin
by Dsmith9583 on Sun Dec 30, 2018 5:47 am
I am have the same problem. i am running Windows 10. using the Arduino IDE 1.8.8 i have unistalled and reinstalled the IDE and adafruit package. the gemma directory does not show up in the bootloader directory. any idea why?
i have read and gone over the instructions several times with out luck.
error message below
Thank You
David
Arduino: 1.8.8 (Windows 10), Board: "Adafruit Gemma (ATtiny85 @ 8MHz)"
Sketch uses 700 bytes (13%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
C:\Users\dsmit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\dsmit\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13/bootloaders/gemma/avrdude.conf -v -pattiny85 -carduinogemma -Uflash:w:C:\Users\dsmit\AppData\Local\Temp\arduino_build_202161/Gamma_Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\dsmit\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13/bootloaders/gemma/avrdude.conf"
avrdude: can't open config file "C:\Users\dsmit\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13/bootloaders/gemma/avrdude.conf": No such file or directory
avrdude: error reading system wide configuration file "C:\Users\dsmit\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13/bootloaders/gemma/avrdude.conf"
Dsmith9583
by Dsmith9583 on Sun Dec 30, 2018 3:47 pm
I was able to get this working. Under Tools / Programer I selected "USBtinyISP" and Not "Arduino Gemma"
I hope this helps anyone else having this problem.
Best Regards
David
Dsmith9583
cron
