Hi all. just purchased an Adafruit Flora and I'm experiencing some issues with setup. I'm not at my computer right now, so apologies that I can't give exact error messages, I can update those later today.
On plugging the device in via USB the red light begins flashing, indicating the board is receiving power. When I try to upload a sketch I get an error saying that the board is not detected on the selected port, though the Arduino IDE clearly is able to identify it on that port by name (COM Adafruit Flora). I appears normally in the Windows Device Manager as well. Arduino IDE is able to pull board information from the port and tell me that there is a Flora connected.
I found some reports that this can be remedied by pressing the reset button as a sketch is uploaded. This works and gets the code to begin transferring, but when it tries to connect to the butterfly programmer it is unable to establish a connection.
I've also read that putting a USB 2.0 hub in between the computer and the device has removed this problem for some people. Verification of this method working would be appreciated. I'm currently tracking one of those down, and am open to other suggestions
Thanks in advance for the help, please let me know what other information could be helpful in remedying this and I'll do my best to post it.
Help with Flora Initial Setup
- Franklin97355
Re: Help with Flora Initial Setup
When you get a chance set the preferences to verbose for compile and upload and then post the error log here. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
- SquidMeal
When attempting to upload without hitting the Reset button
When attempting to upload and pressing the Reset button
Sketch uses 4,794 bytes (16%) of program storage space. Maximum is 28,672 bytes.
Global variables use 153 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM1, COM5, } / {COM1, COM5, } => {}
PORTS {COM1, COM5, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
processing.app.debug.RunnerException: Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at cc.arduino.packages.uploaders.SerialUploader.waitForUploadPort(SerialUploader.java:234)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:130)
at processing.app.debug.Compiler.upload(Compiler.java:163)
at processing.app.Sketch.upload(Sketch.java:1220)
at processing.app.Sketch.exportApplet(Sketch.java:1194)
at processing.app.Sketch.exportApplet(Sketch.java:1166)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487)
at java.lang.Thread.run(Thread.java:745)
PORTS {COM1, } / {COM1, COM5, } => {COM5, }
Found upload port: COM5
D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Chris\AppData\Local\Temp\build8407583432570803698.tmp/sketch_sep13a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
- adafruit2
quesiton, did it ever work?
- SquidMeal
No, it still is refusing to upload.
- adafruit2
mysterious! well lets try replacing it, see if that helps - email support@adafruit for a new Flora!
