Help with Flora Initial Setup
SquidMeal
Post by SquidMeal »
Hi all. just purchased an Adafruit Flora and I'm experiencing some issues with setup. I'm not at my computer right now, so apologies that I can't give exact error messages, I can update those later today.
On plugging the device in via USB the red light begins flashing, indicating the board is receiving power. When I try to upload a sketch I get an error saying that the board is not detected on the selected port, though the Arduino IDE clearly is able to identify it on that port by name (COM Adafruit Flora). I appears normally in the Windows Device Manager as well. Arduino IDE is able to pull board information from the port and tell me that there is a Flora connected.
I found some reports that this can be remedied by pressing the reset button as a sketch is uploaded. This works and gets the code to begin transferring, but when it tries to connect to the butterfly programmer it is unable to establish a connection.
I've also read that putting a USB 2.0 hub in between the computer and the device has removed this problem for some people. Verification of this method working would be appreciated. I'm currently tracking one of those down, and am open to other suggestions
Thanks in advance for the help, please let me know what other information could be helpful in remedying this and I'll do my best to post it.
Franklin97355
Re: Help with Flora Initial Setup
Post by Franklin97355 »
When you get a chance set the preferences to verbose for compile and upload and then post the error log here. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
SquidMeal
Post by SquidMeal »
When attempting to upload without hitting the Reset button
Sketch uses 4,794 bytes (16%) of program storage space. Maximum is 28,672 bytes.
Global variables use 153 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM1, COM5, } / {COM1, COM5, } => {}
PORTS {COM1, COM5, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
processing.app.debug.RunnerException: Couldn't find a Board on the selected port. Check that you have the correct port selected.  If it is correct, try pressing the board's reset button after initiating the upload.
	at cc.arduino.packages.uploaders.SerialUploader.waitForUploadPort(SerialUploader.java:234)
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:130)
	at processing.app.debug.Compiler.upload(Compiler.java:163)
	at processing.app.Sketch.upload(Sketch.java:1220)
	at processing.app.Sketch.exportApplet(Sketch.java:1194)
	at processing.app.Sketch.exportApplet(Sketch.java:1166)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487)
	at java.lang.Thread.run(Thread.java:745)
When attempting to upload and pressing the Reset button
PORTS {COM1, } / {COM1, COM5, } => {COM5, }
Found upload port: COM5
D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\Chris\AppData\Local\Temp\build8407583432570803698.tmp/sketch_sep13a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
adafruit2
Post by adafruit2 »
quesiton, did it ever work?
SquidMeal
Post by SquidMeal »
No, it still is refusing to upload.
adafruit2
Post by adafruit2 »
mysterious! well lets try replacing it, see if that helps - email support@adafruit for a new Flora!
Return to “Arduino”
