WARNING: Spurious .github folder in 'DHT sensor library' library
WARNING: Spurious .github folder in 'RTClib' library
When uploading bme680test sketch for first time with the above messages displayed in error log,
and upload failed.
I am uploading to an Arduino Genuino Uno in the bme680 Tutorial I see the board used is a Metro.
I don't understand why the above Spurious folder warnings even came about I am not including either a real time clock or anything DHT.
Is there something sketchy, no pun intended with import sensor_h ???
The following is a copy of the error log :
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Kevin\Documents\Arduino\libraries\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Kevin\Documents\Arduino\libraries\libraries\Adafruit_BME680_Library\examples\bme680test\bme680test.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Kevin\Documents\Arduino\libraries\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Kevin\Documents\Arduino\libraries\libraries\Adafruit_BME680_Library\examples\bme680test\bme680test.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp\sketch\bme680test.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp\sketch\bme680test.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp\sketch\bme680test.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp\sketch\bme680test.ino.cpp" -o "C:\Users\Kevin\AppData\Local\Temp\build4f75a206249a878f8f99bac8ea14bdc9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\Kevin\Documents\Arduino\libraries\libraries\Adafruit_BME680_Library\examples\bme680test\bme680test.ino:20:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling for board Arduino/Genuino Uno.
Spurious .github folder in DHT sensor library??
- loonhaunt
- Franklin97355
Re: Spurious .github folder in DHT sensor library??
You can ignore the warning or delete the folder. GitHub uses that for indexing I think but Arduino does not recognize it as a valid library file.
- loonhaunt
Ah! Interesting. It must be an artifact from a year ago or whenever I last used this laptop to upload. Arduino IDE has been sitting idle for a year on this machine.
Thanks I will let you know what happens when I give it another shot later today.
