TCS34725 throws a random 44 in serial monitor
Beatrice94
Post by Beatrice94 »
Hi everybody!
I am using TCS34725 from Adafruit to perform color measures and I noticed a very annoying thing: every time the sensor is initialized (tcs.begin(); or if tcs.begin is not called, at the first measurement), a number 44 pops up in my Arduino Serial monitor. After a bit of debugging and digging the library down, I found this
boolean Adafruit_TCS34725::begin(void)
  Wire.begin();
  /* Make sure we're actually connected */
  uint8_t x = read8(TCS34725_ID);
  Serial.println(x, HEX);
  if (x != 0x44)
    return false;
  _tcs34725Initialised = true;
  /* Set default integration time and gain */
  setIntegrationTime(_tcs34725IntegrationTime);
  setGain(_tcs34725Gain);
  /* Note: by default, the device is in power down mode on bootup */
  enable();
  return true;
in the .cpp file of the Adafruit library. Now, I want my results on the serial monitor to be nice as I have to pass them to Processing to be saved on a file, so I'm really really tempted to comment that Serial.println() out so that it doesn't happen again. Can anyone tell me if there is a reason to print out that value other than debugging? Since my system is working aside from that 44, is everything going to blow up if i // the Serial.print?
Re: TCS34725 throws a random 44 in serial monitor
It is just printing the device identification number - verifying that it is indeed a TCS34725. You can safely comment out the Serial.println(x, HEX);.
Beatrice94
Yay! Works smoothly now, thanks!
Return to “Arduino”
