Time of Flight Distance Sensor Error
KFLaieh
Post by KFLaieh »
I have been using the Time of Flight Distance Sensor (https://www.adafruit.com/product/3317) on a project.
The sensor works as intended and gives the correct readings when it is powered by a Regulated 5v power sources.
My end goal for this project is to have it powered by solar power, which means it is a unregulated 4.3v.
On the products information page, it says the sensor will work with any 3-5v power sources. But whenever I power the sensor with the solar power, the sensor does not function properly and only outputs 65,535, which I found out means "Time-Out".
I have no idea why changing only the power source causes the sensor to malfunction so much. Any help or ideas will be appreciated.
adafruit_support_carter
Re: Time of Flight Distance Sensor Error
Can you post a photo of your setup showing how everything is connected.
Return to “Arduino”
