2.8" Capacitive Touch Screen v2 BMP Not Displaying Correctly
SolarBlight
Post by SolarBlight »
I just purchased the Adafruit 2.8" Capacitive Touch Screen v2 shield and mounted it on an Arduino Uno R3. I downloaded the Adafruit ILI9341 version 1.2.9 library, example code 'spitftbitmap' and uploaded the sketch to the Arduino. The sketch is supposed to display a bmp in a continuous loop. The bitmap first displays one quarter of the image at the bottom left-hand corner and afterwards it displays the full image and then one quarter of the bmp is displayed in the upper right-hand corner as shown in the photo sequence below. It seems like the origin of the BMP is moving up and over one half of the screen each time it redraws.
After searching the forum and internet I haven't found any similar problem. The only change that I've made to the code is commenting out the first 'for' loop in the image rotation section in the void loop.
The example sketch 'graphicstest' runs fine, so I'm not sure why 'spitftbitmap' doesn't work properly.
  //for(uint8_t r=0; r<4; r++) {           //'for' loop commented out
    tft.setRotation(0);                        // *****Changed to '0', used to be 'r'    *******
    tft.fillScreen(ILI9341_BLUE);
    for(int8_t i=-2; i<1; i++) {
      bmpDraw("purple.bmp",
        (tft.width()  / 2) + (i * 120),
        (tft.height() / 2) + (i * 160));
 // }                                                   //end of 'for' loop commented out
display problem 1.jpg (23.17 KiB) Viewed 267 times
display problem 3.jpg (31.12 KiB) Viewed 267 times
display problem 5.jpg (31.1 KiB) Viewed 267 times
adafruit_support_carter
Re: 2.8" Capacitive Touch Screen v2 BMP Not Displaying Corre
Does it work OK if you leave the loop in and run the example unmodified?
SolarBlight
No, I still get the same problem when adding the loop function back in the sketch. Is there anything else I can do to test it?
OK. I just tested this and I'm getting the same thing. I'm wondering if something has changed with the GFX library. I'll pass this on.
adafruit2
Post by adafruit2 »
its not rotating but it *is* supposed to be moving correctly.
"bmpDraw("purple.bmp",
(tft.height() / 2) + (i * 160));"
means draw in different quadants as i increments
do you need to display rotated bitmaps? if not, this doesnt matter
either way its something in our bitmap drawing that doesnt handle rotating, but the hardware is fine
SolarBlight
I don't want to display a rotating image just a static BMP.
adafruit2
Post by adafruit2 »
ok, well it works then?
SolarBlight
No, even if I put the for loop back in the code it still moves the point of origin and appears fractured.
adafruit2
Post by adafruit2 »
it should, its drawing in offset locations!
SolarBlight
Sorry I haven't been able to get back to you in a while. I don't want the TFT to draw in offset locations, is there something in the code I can change to just show the full STATIC bmp?
adafruit2
Post by adafruit2 »
remove the loop code - if this is your first arduino project you may want to try some simpler ones to start!
SolarBlight
Thanks for the help, I modified the code in the loop function and now it's working fine.
modified code:
  //for(uint8_t r=0; r<4; r++) {                 // I want a still image so I commented out the rotation loop
    tft.setRotation(0);                              // fixed rotation to "0"
    for(int8_t i=-1; i<0; i++) {                 // Changed i=-2 to i=-1 and i<1 to i<0 so the FOR LOOP executes only once
      bmpDraw("flowers.bmp",0,0);
      // (tft.width()  / 2) + (i * 120),         // removed the x origin calculation and fixed it as "0" in bmpDraw function
      // (tft.height() / 2) + (i * 160));        // removed the y origin calculation and fixed it as "0" in bmpDraw function
flowersBMP small.jpg (101.34 KiB) Viewed 150 times
Return to “Arduino”
