I think I have a faulty Metro.
When I try and upload any sketch (even the most basic example Blink sketch) I get the following errors;
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x94
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
I then try another program that tests an attached wave shield. The wave shield tests fine with another Metro, so I know the problem is not there.
Once I try and compile and upload the sketch I get these errors.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10806 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_771160 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_211021 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\code\Arduino\Talking Clock\sketch_wave_shield\sketch_wave_shield.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10806 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_771160 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_211021 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\code\Arduino\Talking Clock\sketch_wave_shield\sketch_wave_shield.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\John\\Documents\\Arduino\\libraries\\WaveHC" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\WaveHC\FatReader.cpp
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\WaveHC\SdReader.cpp
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\WaveHC\WaveHC.cpp
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\WaveHC\WaveUtil.cpp
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\John\\Documents\\Arduino\\libraries\\WaveHC" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp" -o "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\John\\Documents\\Arduino\\libraries\\WaveHC" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp" -o "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp.o"
Compiling libraries...
Compiling library "WaveHC"
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\libraries\WaveHC\WaveHC.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\libraries\WaveHC\FatReader.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\libraries\WaveHC\SdReader.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\libraries\WaveHC\WaveUtil.cpp.o
Compiling core...
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\hooks.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\WInterrupts.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring_analog.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring_shift.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring_digital.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\wiring.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\abi.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\WString.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\new.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\WMath.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\CDC.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\Print.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\USBCore.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\Stream.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\main.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\Tone.cpp.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_771160\core\core.a
Archiving built core (caching) in: C:\Users\John\AppData\Local\Temp\arduino_cache_211021\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.elf" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\sketch\\sketch_wave_shield.ino.cpp.o" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\libraries\\WaveHC\\FatReader.cpp.o" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\libraries\\WaveHC\\SdReader.cpp.o" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\libraries\\WaveHC\\WaveHC.cpp.o" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160\\libraries\\WaveHC\\WaveUtil.cpp.o" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/core\\core.a" "-LC:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.elf" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.elf" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.hex"
Using library WaveHC at version 1.0.0 in folder: C:\Users\John\Documents\Arduino\libraries\WaveHC
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_771160/sketch_wave_shield.ino.elf"
Sketch uses 14588 bytes (45%) of program storage space. Maximum is 32256 bytes.
Global variables use 1521 bytes (74%) of dynamic memory, leaving 527 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\John\AppData\Local\Temp\arduino_build_771160/sketch_wave_shield.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\John\AppData\Local\Temp\arduino_build_771160/sketch_wave_shield.ino.hex"
avrdude: writing flash (14588 bytes):
Writing | ################################################## | 100% 5.47s
avrdude: 14588 bytes of flash written
avrdude: verifying flash memory against C:\Users\John\AppData\Local\Temp\arduino_build_771160/sketch_wave_shield.ino.hex:
avrdude: load data flash data from input file C:\Users\John\AppData\Local\Temp\arduino_build_771160/sketch_wave_shield.ino.hex:
avrdude: input file C:\Users\John\AppData\Local\Temp\arduino_build_771160/sketch_wave_shield.ino.hex contains 14588 bytes
avrdude: reading on-chip flash data:
Reading |
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x01
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
Have I killed this Metro, or is there some magic I can do to get it going again? I do have a spare Metro so it is not a total loss, but it would be good to get this one back to normal working order if possible. The errors seem to indicate an issue when writing to the flash memory on the board?
