Hey there,
I’ve got this project running:
https://learn.adafruit.com/wifi-weather ... y/overview
But I want to use a M0 WiFi feather instead, this one:
https://www.adafruit.com/product/3010?
Reason being I have the wrong headers on the ESP8266 so am currently hand wired and want the compactness of plugging the board right into the feather wing
Any advice on how to make this work in terms of code updates? I know I have to reassign some of the pins.
Weather station 8266 feather project with different feather
- martian
- Franklin97355
Re: Weather station 8266 feather project with different feat
Take the code you have and try compiling it for the M0. If that works you know you have a chance, if not fix the code first.
- martian
Hey Franklin, thanks!
S0, not, it doesn’t compile.
I get this:
/var/folders/lk/_6vdh08x2b14r_z59l3nmysw0000gn/T/arduino_modified_sketch_53717/esp8266-weather-station-color.ino:29:49: fatal error: ESP8266WiFi.h: No such file or directory #include <ESP8266WiFi.h>
Which makes sense as it is not an ESP8266.
I swapped this for the WiFi library I have used before with the Feather M0:
#include <WiFi101.h>
But then I get this:
Documents/Arduino/libraries/Mini_Grafx/src/MiniGrafx.h:31:16: fatal error: FS.h: No such file or directory #include <FS.h>
Googling <FS.h> I learned it is something called a “file system wrapper”, button sure what that is or if i can work around it.
Not sure if i should try and modify that library, or …?
I get this:
