I built this over the last few years. Functional 10meter LIDAR (IR DAR!), 2x50mw lasers, Adafruit neopixels, ADA 1.8 TFT, FXMini, trinkets-a-plenty, Teensy 3.2, TFMini, crystals, C++ code (which of course could be made better, but this was my first 'real' code project), and plenty of 3D print parts. The PLASMA CRYSTAL (the 'power source') in the 'clip' uses about 99% of a trinket memory and the code is really cool, random (to limits of randomness for C++) fiery glowing Neopixels shining through a real crystal!
Would be a very long post so if interested, you can read about it here:
https://www.thingiverse.com/thing:3144301
Vids:
Laser Blaster Overview w/Plasma Crystal
https://www.youtube.com/watch?v=HWKC-wcrbZE&t=3s
LIDAR walking towards wall 6m away
https://www.youtube.com/watch?v=ngPoOk9 ... e=youtu.be
LAser Blaster w/LIDAR
https://www.youtube.com/watch?v=OzD6tEk0OKQ
XRAD'S Real Laser Blaster W/LIDAR
- XRAD
Re: XRAD'S Real Laser Blaster W/LIDAR
Code for above project:
#include <TFT.h>
#include <SPI.h>
#include <TFMini.h>
#include <Servo.h>
//Teensy 3.2 pin definitions for Adafruit 1.8TFT:
#define DC 9
#define CS 10
#define MOSI 11
#define RST 12
#define SCK 13
#define SERVO_PIN 23 // servo control signal
// teensy 3.2 pin out HIGH to base of 3904 transistors,
// which then grounds FXmini 8 triggers for sounds
#define PINAUDIO1 14 // scanner start sound
#define PINAUDIO2 15 // scanner cycle default sound
#define PINAUDIO3 16 // scanner object >0m & <1m
#define PINAUDIO4 17 // scanner object >1m & <2m
#define PINAUDIO5 18 // scanner object >2m & <3m
#define PINAUDIO6 19 // scanner object >3m & <4m
#define PINAUDIO7 20 // scanner object >4m & <5m
#define PINAUDIO8 21 // scanner object >5m & <6m
#define BLACK 0x0000 // 16 bit color choices
#define RED 0x001F
#define CYAN 0x07FF
#define GREEN 0x0400
#define MAGENTA 0xF81F
#define BLUE 0xF800
#define WHITE 0xFFFF
#define YELLOW 0xFFE0
const int r_beam = 100; // pixel length of green scan radius
const int r2 = (r_beam * .33);
const int r3 = (r_beam * .66);
const int rMin = 0;
const int rMax = 600;
TFT tft = TFT( CS, DC, RST );
Servo servo;
TFMini tfmini;
// distance char array to print to the screen
char rc_Printout[ 5 ];
int interval = 0;
double distance = 0;
int r_beam1 = 10;
void setup( )
servo.attach( SERVO_PIN );
Serial.begin(115200);
// set up audio , use any sounds you like
pinMode(PINAUDIO1, OUTPUT); // turn on sound
pinMode(PINAUDIO2, OUTPUT); // background humm sound
pinMode(PINAUDIO3, OUTPUT); //ping
pinMode(PINAUDIO4, OUTPUT); //ping
pinMode(PINAUDIO5, OUTPUT); //ping
pinMode(PINAUDIO6, OUTPUT); //ping
pinMode(PINAUDIO7, OUTPUT); //ping
pinMode(PINAUDIO8, OUTPUT); //ping
//start the TFMini
Serial1.begin(TFMINI_BAUDRATE);
tfmini.begin(&Serial1);
delay(100);
tfmini.setSingleScanMode();
//clear the TFT
tft.begin( );
tft.background( BLACK );
delay(200);
digitalWrite(PINAUDIO1, HIGH); // start up sound
delay(100);
digitalWrite(PINAUDIO1, LOW);
//cool start up visual
for ( int i = 0; i < 3; i ++ )
tft.setTextSize( 2 );
tft.stroke( RED );
tft.text( "WARNING", 40, 20 );
tft.text( "INITIALIZING", 10, 40 );
tft.text( "LIDAR", 50, 60 );
tft.stroke( WHITE );
tft.text( "MAX RANGE 10m", 4, 90 );
tft.stroke( GREEN );
tft.rect( 2, 2, 158, 124 ) ;
delay(500);
tft.stroke( RED );
tft.text( "RANGE", 10, 1 );
for ( int i = 0; i < 3; i ++)
for ( int i = 0 ; i < 10 ; i++) {
tft.stroke (BLUE);
tft.fill (BLACK);
tft.circle(80, 117,(r_beam1 * i));
delay(10);
tft.stroke( RED );
tft.setTextSize( 1 );
tft.text( "10m", 3, 38 );
// here comes my cool pulse LIDAR ring effect
for ( int i = 0; i < 3; i ++) {
tft.stroke (BLUE);
tft.fill (BLACK);
tft.circle(80, 117, ((r_beam1 * .66) * i));
delay(15);
tft.stroke( RED );
tft.text( "6.5m", 15, 78 );
tft.stroke (BLUE);
tft.fill (BLACK);
tft.circle(80, 117, ((r_beam1 * .33) * i));
delay(30);
tft.stroke( RED );
tft.text( "3.3m", 30, 120 );
void loop( )
tft.stroke( BLUE );
tft.circle( 80, 128, r_beam );
tft.circle ( 80, 128, r_beam - r2 );
tft.circle ( 80, 128, r_beam - r3);
tft.stroke( RED );
tft.stroke( RED );
//Left display/servo rotation
for ( int i = 60; i < 120; i = i + 1 )
{ tfmini.externalTrigger();
uint16_t distance = tfmini.getDistance();
servo.write( i );
delay( 30 ); //any longer and scans a bit slow, any less and too fast for clean display/sound activation
//This is for 10m display range
int r = distance * 0.1;
String r_Printout = String( r * 0.1 );
if ( r <= 100 ) {
tft.stroke( 0, 0, 0 );
tft.text( rc_Printout, 100, 0 );
r_Printout.toCharArray( rc_Printout, 5 );
//Sound control of FXMini
//I am sure this can be done in an array, but this is very fast
int range = map(distance, rMin, rMax, 0, 5);
switch (range) {
case 0:
digitalWrite(PINAUDIO2, LOW);
digitalWrite(PINAUDIO4, LOW);
digitalWrite(PINAUDIO5, LOW);
digitalWrite(PINAUDIO6, LOW);
digitalWrite(PINAUDIO7, LOW);
digitalWrite(PINAUDIO8, LOW);
digitalWrite(PINAUDIO3, HIGH);
Serial.println(PINAUDIO3);
break;
case 1:
digitalWrite(PINAUDIO3, LOW);
digitalWrite(PINAUDIO4, HIGH);
Serial.println(PINAUDIO4);
break;
case 2:
digitalWrite(PINAUDIO5, HIGH);
Serial.println(PINAUDIO5);
break;
case 3:
digitalWrite(PINAUDIO6, HIGH);
Serial.println(PINAUDIO6);
break;
case 4:
digitalWrite(PINAUDIO7, HIGH);
Serial.println(PINAUDIO7);
break;
case 5:
digitalWrite(PINAUDIO8, HIGH);
Serial.println(PINAUDIO8);
break;
default:
digitalWrite(PINAUDIO2, HIGH);
Serial.println(PINAUDIO2);
tft.line( 80, 128, 80 + r_beam * cos( ( 360 - i ) * 3.14 / 180 ), 128 + r_beam * sin( ( 360 - i ) * 3.14 / 180 ) );
if ( r > 0 && r <= r_beam + 2 )
tft.circle( 80 + r * cos( ( 360 - i ) * 3.14 / 180 ), 128 + r * sin( ( 360 - i ) * 3.14 / 180 ), 2 ); // might not be necessary
tft.fillCircle( 80 + r * cos( ( 360 - i ) * 3.14 / 180 ), 128 + r * sin( ( 360 - i ) * 3.14 / 180 ), 2 , RED );
if (r < r2) {
tft.fillCircle( 80 + r * cos( ( 360 - i ) * 3.14 / 180 ), 128 + r * sin( ( 360 - i ) * 3.14 / 180 ), 2 , WHITE );
tft.stroke( BLUE );
tft.stroke( RED );
tft.stroke( RED );
//Right display/servo rotation
for ( int i = 120; i > 60; i = i - 1 )
servo.write( i );
delay( 30 );
if ( r <= 100 ) {
switch (range) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
default:
if (r < r2) {
uint16_t color565( uint8_t r, uint8_t g, uint8_t b )
return ( ( r & 0xF8 ) << 8 ) | ( ( g & 0xFC ) << 3 ) | ( b >> 3 );
- XRAD
I am in the process of coding a faster way to scan an area using LIDAR without a 360 degree rotating head. It will have increased range and a faster sweep interleaved with a visual pulse cycle on the TFT..... So it should send out one pulse ring and draw the image about 1/sec, possibly with smoother blending of colors for distance....
