Feather M0 analogread() very slow...
jarekdudzinski
Post by jarekdudzinski »
Hi :)
I'm trying to capture a lot of analog data over shortest possible time. Was working on standard Arduino Uno, but after testing, it's too slow - 5000 consecutive analog reads takes 560ms. Then I thought about my Feather M0 - with much faster processor speed.
I've quickly connected it, uploaded the same code I've used on Uno board and... 5000 reads is taking 2117 ms! :O
Pasting my test code - did I'm missing something, or it really is slower than Uno? :/
  unsigned long startTime = 0;
  unsigned long endTime = 0;
  int sensorValue = 0;
  startTime = micros();
  for (int i=0; i<5000; i++) {
    sensorValue = analogRead(A0);
  endTime = micros();
  Serial.print("Time: ");
  Serial.print( float (endTime-startTime)/1000.0 );
  Serial.print(" ms");
  Serial.print("\n");
  Serial.print("Last value: ");
  Serial.print(sensorValue);
  Serial.print("\n\n");
zener
Re: Feather M0 analogread() very slow...
Post by zener »
My initial guess is it's because the feather can produce a 14 bit result vs the Arduino 10 bit result. A 14 bit read takes longer. However, this info:
https://learn.adafruit.com/bluefruit-nr ... /nrf52-adc states that the default is 10 bits. But you might try using the analogReadResolution(...) function to set it to 10 and see if that helps. You could also set it lower and that should speed it up some.
The ADC resolution can be set to 8, 10, 12 or 14 bits using the analogReadResolution(...) function, with the default value being 10-bit:
Good luck
jarekdudzinski
You are looking at different board than mine. I have M0 version with Bluetooth module. It’s analog output is 10bits.
zener
Post by zener »
If it is the D21 processor it can do 12 bit AD reads. Which exact product are you using?
jarekdudzinski
This one: https://www.adafruit.com/product/2995
Normally, it gives 10bit (0-1023 value) output on ADC pins.
The ATSAMD21 has 12 bit resolution on the ADC. https://www.microchip.com/wwwproducts/ATsamd21g18
The AnalogRead() in the Arduino IDE defaults to 10 bits for backward compatibility. But it allows you to specify a higher resolution on processors that support it: https://www.arduino.cc/reference/en/lan ... esolution/
Return to “Arduino”
