I've built a circuit to fire the shutter release on my camera. It uses the digital pin output from an arduino driving a 4N25 optocoupler.
The arduino digital pin goes through a 330ohm resistor to pin 1 of the 4N25. pin 2 goes to ground.
The shutter release is caused by closure across pins 4 and 5 of the 4N25.
It works but it doesn't 'completely' release. My camera always senses the shutter button being 'slightly' pressed.
Is there a way to remedy this?
Thanks in advance.
mark
issue with arduino controlled optocoupler
- zener
Re: issue with arduino controlled optocoupler
Short answer, you can try a bigger resistor. Long answer, we would need to do some measurements to see what might be going on, and see the connections, etc.
Thanks.
I think I found the problem - a bit of solder residue between the emitter and collector.
seems better now.
seems better now.
