// Include IR Remote Library by Ken Shirriff
#include <IRremote.h>
// Define sensor pin
const int RECV_PIN = 9;
// Define integer to remember toggle state
int togglestate = 0;
int duration = 500;
int soundTone = 500;
// Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
// Enable the IR Receiver
irrecv.enableIRIn();
// Set LED pins as Outputs
pinMode(8, OUTPUT);
void loop(){
if (togglestate == 1){
tone(8,soundTone);
delay(duration);
noTone(8);
delay(duration);}
else{
noTone(8);}
if (irrecv.decode(&results)){
switch(results.value){
case 0x3AFB26D4: //Down Button
if(soundTone > 50){
soundTone = soundTone - 50;
delay(100);}
else{
soundTone = soundTone;
delay(100);}
break;
case 0xE246AFCA: //Up Button
if (soundTone < 55){
soundTone = soundTone + 50;
delay(100);}
else{
delay(100);}
break;
case 0x4D43596A: //Left Button
if (duration > 0){
duration = duration - 100;
delay(100);}
else{
duration = duration;
delay(100);}
case 0xBB0EDD22: //Right Button
if (duration < 1500){
duration = duration + 100;
delay(100);}
else{
delay(100);}
case 0x406A954D: //Power Button
if(togglestate==0){
togglestate = 1;
delay(300);}
else {
togglestate = 0;
delay(300);}
break;
irrecv.resume();
Arduino: 1.8.7 (Windows 8.1), Board: "Arduino/Genuino Uno"
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\IRremote\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
