Error Compiling for board Arduino/Genuio Uno
RPi_Zero
Post by RPi_Zero »
I am trying to make a script that allows me to change the duration and tone of a speaker using and IR remote. For some reason I keep getting a Error Compiling for board Arduino/Genuio Uno error. Here's my code:
// Include IR Remote Library by Ken Shirriff
#include <IRremote.h>
// Define sensor pin
const int RECV_PIN = 9;
// Define integer to remember toggle state
int togglestate = 0;
int duration = 500;
int soundTone = 500;
// Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
  // Enable the IR Receiver
  irrecv.enableIRIn();
  // Set LED pins as Outputs
  pinMode(8, OUTPUT);
void loop(){
    if (togglestate == 1){
      tone(8,soundTone);
      delay(duration);
      noTone(8);
      delay(duration);}
    else{
      noTone(8);}
    if (irrecv.decode(&results)){
        switch(results.value){
          case 0x3AFB26D4: //Down Button
        if(soundTone > 50){
          soundTone = soundTone - 50;
          delay(100);}
        else{
          soundTone = soundTone;
          delay(100);}
        break;
          case 0xE246AFCA: //Up Button
        if (soundTone < 55){
          soundTone = soundTone + 50;
          delay(100);}
        else{
          delay(100);}
        break;
          case 0x4D43596A:  //Left Button
        if (duration > 0){
          duration = duration - 100;
          delay(100);}
        else{
          duration = duration;
          delay(100);}
          case 0xBB0EDD22:  //Right Button
        if (duration < 1500){
          duration = duration + 100;
          delay(100);}
        else{
          delay(100);}
          case 0x406A954D: //Power Button
        if(togglestate==0){
          togglestate = 1;
          delay(300);}
        else {
          togglestate = 0;
          delay(300);}
        break;
    irrecv.resume();
Here's the error:
Arduino: 1.8.7 (Windows 8.1), Board: "Arduino/Genuino Uno"
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\IRremote\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
Any help would be awesome. Thanks!
adafruit2
Re: Error Compiling for board Arduino/Genuio Uno
Post by adafruit2 »
see if you need to update IRRemote, looks like it no longer compiles due to arduino changes?
RPi_Zero
Post by RPi_Zero »
But any other IRRemote script that I have made works fine. Far as I can tell, IRRemote and tone() are clashing. But I am not sure.
Plus I just installed the library less than two weeks ago with the latest version.
adafruit2
Post by adafruit2 »
cant use tone then!
RPi_Zero
Post by RPi_Zero »
Hmmm....
But then how to make a tone?
Return to “Arduino”
