Getting an error, can't figure out how to fix... Help!
epullis
Post by epullis »
Hey there! So, I'm testing out some things for an LED project that I'm working on/teaching myself how to program a gemma via trial by error. I'm trying to set up a sparkle-type animation with multiple colors. For the most part I've been able to figure out errors and fix them, but I can't seem to figure out how to fix this one.
Here's the error:
Death_Test:39: error: 'pixels' does not name a type
Death_Test:40: error: 'pixels' does not name a type
Death_Test:41: error: expected constructor, destructor, or type conversion before '(' token
Death_Test:42: error: 'pixels' does not name a type
Death_Test:43: error: 'pixels' does not name a type
Death_Test:44: error: 'pixels' does not name a type
Death_Test:45: error: 'pixels' does not name a type
Death_Test:47: error: expected declaration before '}' token
exit status 1
and here's the code i'm working with
#define PIN 1
#define NUMPIXELS 20
#define DELAY_MILLIS 30
#define DELAY_MULT 8
#define BRIGHT 60
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
uint8_t myFavoriteColors[][3] = {(242, 90, 255),
                                 (255, 222, 30),
                                 (255, 100, 0),
#define FAVCOLORS sizeof myFavoriteColors/3
  pixels.begin();
  pixels.setBrightness(BRIGHT);
  pixels.show();
  int RColor = random(FAVCOLORS);
  //sparkling
  int p = random(NUMPIXELS); //select a random pixel
  pixels.setPixelColor(p, RColor);
  pixels.show();
  delay(DELAY_MILLIS * random(DELAY_MULT) );
  pixels.setPixelColor(p, RColor/10);
  pixels.show();
  pixels.setPixelColor(p+1, RColor/15);
  pixels.show();
adafruit_support_carter
Re: Getting an error, can't figure out how to fix... Help!
You have an extra "}" in your code. Remove the last line here:
epullis
Post by epullis »
adafruit_support_carter wrote:You have an extra "}" in your code. Remove the last line here:
whelp... not gonna lie, im almost mad at how easy that was lol thank you!
Return to “Arduino”
