I like to use the ItsyBitsyM0 Express with an Arduino Sketch (without CircuitPython), in detail I am using PlatformIO to build everything. The program I created works, BUT it does not start automatically after power-on (from e.g. battery). I always have to press the reset button once, then the program starts.
Why? How can I acchieve it, so that the program starts immediately?
Arduino starts only after a press on reset button with ItsyB
- adafruitition
- zener
Re: Arduino starts only after a press on reset button with I
It may help to post your code (in a code box, click [CODE} button above when replaying). There may be something in there that is causing the problem, for example, initializing a serial connection when one is not connected. Others may have a better idea.
