Hi All,
Using the example bmp sketch (File >> Examples >> Adafruit SSD1351 Library >> bmp) provided by Adafruit, I can correctly display the example image (lily128.bmp). However, if I want to grab an jpeg image from the internet and then convert that image to a bmp (128x128 pixel, 24 bit depth, file size is around 45KB), the example sketch keeps on outputting that it cannot read the file. I believe there is something wrong with the conversion...
Do you all know the correct way to convert a jpg to a bmp file and have it work with the OLED using the SSD1351 display driver, if that is what is wrong?
I had also noticed that the converted bmp file contents looks a little bit different than the lily128.bmp file via Notepad++ which leads me to believe that the bmp file is the suspect.
Thank you for your help!
Arduino Uno with 1.5" OLED SSD1351 Driver - Problems reading
- goradiar
- goradiar
Re: Arduino Uno with 1.5" OLED SSD1351 Driver - Problems rea
Well, I just came across the solution.
Instead of trying to use an online converter, I used MS Paint or Paint.net to resize and save as a bmp file, and it worked...
So, if anybody came across this problem, don't use an online converter.
- dennisonb
Is it possible for you to share the wiring and code you used to make the bmp example work? I am following it but can not get it to work, (I can get the display to work, just not display bmp files).goradiar wrote:Hi All,
Thank you
