viewtopic.php?f=25&t=103967
I tried to upload this code (https://learn.adafruit.com/getting-star ... nboard-led) on my Flora module. I tried with different USB cables but it's still the same... when the upload starts, Flora is disconnected.
here is the message:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Vykk\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Vykk\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries F:\Users\Vykk\Documents\Arduino\libraries -fqbn=adafruit:avr:flora8 -vid-pid=0X239A_0X8004 -ide-version=10807 -build-path F:\AppData\Local\Temp\arduino_build_454362 -warnings=none -build-cache F:\AppData\Local\Temp\arduino_cache_155643 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\Users\Vykk\Documents\Baligane Robe\sketch_nov12a\sketch_nov12a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Vykk\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Vykk\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries F:\Users\Vykk\Documents\Arduino\libraries -fqbn=adafruit:avr:flora8 -vid-pid=0X239A_0X8004 -ide-version=10807 -build-path F:\AppData\Local\Temp\arduino_build_454362 -warnings=none -build-cache F:\AppData\Local\Temp\arduino_cache_155643 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\Users\Vykk\Documents\Baligane Robe\sketch_nov12a\sketch_nov12a.ino
Using board 'flora8' from platform in folder: C:\Users\Vykk\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.13
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\Vykk\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.13\\variants\\flora" "F:\\AppData\\Local\\Temp\\arduino_build_454362\\sketch\\sketch_nov12a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\Vykk\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.13\\variants\\flora" "F:\\AppData\\Local\\Temp\\arduino_build_454362\\sketch\\sketch_nov12a.ino.cpp" -o "F:\\AppData\\Local\\Temp\\arduino_build_454362\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "F:\\AppData\\Local\\Temp\\arduino_build_454362\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\Vykk\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.13\\variants\\flora" "F:\\AppData\\Local\\Temp\\arduino_build_454362\\sketch\\sketch_nov12a.ino.cpp" -o "F:\\AppData\\Local\\Temp\\arduino_build_454362\\sketch\\sketch_nov12a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: F:\AppData\Local\Temp\arduino_cache_155643\core\core_adafruit_avr_flora8_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.elf" "F:\\AppData\\Local\\Temp\\arduino_build_454362\\sketch\\sketch_nov12a.ino.cpp.o" "F:\\AppData\\Local\\Temp\\arduino_build_454362/..\\arduino_cache_155643\\core\\core_adafruit_avr_flora8_0c812875ac70eb4a9b385d8fb077f54c.a" "-LF:\\AppData\\Local\\Temp\\arduino_build_454362" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.elf" "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.elf" "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "F:\\AppData\\Local\\Temp\\arduino_build_454362/sketch_nov12a.ino.elf"
Sketch uses 4130 bytes (14%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM6
PORTS {COM6, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
Regards
